Rear brakes
02-03-2023, 12:54 PM
Rear brakes
This is in reference to a standard AE86 disc braked axle.
On the face of it what l'd like to sounds daft but hear me out. For the purpose of the car l want the facility to use 13" wheels. l want to use a hydraulic handbrake using dedicated calipers. Currently the hydralic is working in line with the standard rear calipers but using a standard lever (regulations) the handbrake is only just good enough. This is basically a piston / master cylinder size issue, plus l don't like inline handbrakes. So.. To allow clearance for the wheels and attain a larger piston l'm considering fitting AE86 front calipers to the rear as a dedicated caliper. I have some T3 adaptor plates (quad caliper) understandably the front '86 calipers don't fit. Nissan S13/14:calipers do fit but l doubt a 13" wheel would clear. The Wilwood caliper option uses the same size piston as the rear AE86. Has anyone done anything like rhis? An analogue brain in a digital World |
Switching diffs for disc brakes? | trippin | 6 | 3,133 |
07-08-2022 03:35 AM Last Post: trippin |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,927 |
Hydraulic handbrake with stock rear brakes | Dino86 | 11 | 16,178 |
07-11-2014 08:33 PM Last Post: Dino86 |
S13 Front brakes in AE86 rear | heshan | 25 | 29,550 |
02-01-2014 12:37 PM Last Post: heshan |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 6,167 |
