Rebuilding steering rack, which parts to renew?
10-18-2008, 05:05 PM
Has anybody any experience with rebuilding a steering rack?
I want to build in the QSR this week, so if anyone has any info, or better yet, a pictorial on this matter that would be great. ![]() Mainly I'm looking for the parts I can better renew while I'm at it, rings, gaskets etc. Thanks, Aram. |
10-18-2008, 05:10 PM
Rebuilding steering rack, which parts to renew? | |||
10-22-2008, 05:40 AM
There's only a 'handful' of renewable parts.
2x bearings on the pinion gear 1x pinion shaft seal 1x rack shaft end bushing 2x tie rod end boots. with new molybdenium grease and its good to go. Andrew |
10-22-2008, 06:02 PM
assassin10000 Wrote:There's only a 'handful' of renewable parts. I found these partnumbers, the bold ones are specificly for the AW11 rack, which I have, the other ones are for both. My technical english is not good enough to recognize every item you listed above, but I will try to connect them. I will make them red, can you confirm if this is ok? 45046-29135 Outer Tie Rod End (x2 LH and RH are the same) 45503-19066 Inner Tie Rod End (x2 LH and RH are the same) 45536-12011 Steering Rack Boot (RH 12/84-1/88, LH 12/84-12/89) 45536-17010 RH Steering Rack Boot (1/88-12/89) 90467-18003 Steering Rack Boot Clip (x2) 90461-10273 LH Steering Rack Boot Clamp 90949-01453 RH Steering Rack Boot Clamp 90363-13001 Pinion Gear Lower Bearing (12/84-9/89) 90363-13004 Pinion Gear Lower Bearing (9/89-12/89) 90363-15003 Pinion Gear Upper Bearing (12/84-9/89) 90363-15015 Pinion Gear Upper Bearing (8/89/12/89) 90311-15002 Pinion Gear Oil Seal 44277-17010 Rack Guide Seat I also have heard something about spacers, to lenghten the rack a bit. But I think this is for more steering angle, I found something called the battleversion 2? The rack will work without this and have the normal steering angle? Hope you can let me know. ![]() Thanks Aram |
10-22-2008, 07:02 PM
Yep, those spacers are just for extra steering angle. I believe they are only put on one side of the rack, the picture above just shows the 2 styles of spacers that are commonly used (and in this case manufactured by battleversion).
10-22-2008, 10:50 PM
Ok, then for now I just need the correct part numbers.
![]() Only problem is that the driftday is coming Sunday, so I doubt I will have the rack ready before then. ![]() |
10-23-2008, 07:18 AM
Aram Wrote:I found these partnumbers, the bold ones are specificly for the AW11 rack, which I have, the other ones are for both. IF these are for an AW11 you do NOT want them for a AE86. Use AE86 inner & outer tie rod ends on the AW11 rack - for swapping into an AE86. That would also include using AE86 steering rack boots. 45046-29135 Outer Tie Rod End (x2 LH and RH are the same) 45503-19066 Inner Tie Rod End (x2 LH and RH are the same) These sound like what you need... But I think your missing the 'end' bushing for the passenger side of the rack. 90363-13004 Pinion Gear Lower Bearing (9/89-12/89) 90363-15015 Pinion Gear Upper Bearing (8/89/12/89) 90311-15002 Pinion Gear Oil Seal 44277-17010 Rack Guide Seat A quick check on toyodiy.com and this 'might' be the p# you need for the bushing. BUSH, STEERING RACK 45522-17010 Andrew |
20v BT - which oil pump? | Mylesmck | 4 | 3,066 |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 7,279 |
Quaife quick rack | totta Crolla | 19 | 21,799 |
03-03-2018 03:32 PM Last Post: Deuce Cam |
Rim width. Which is best.... | Dino86 | 5 | 7,029 |
which connector is this | ditn | 7 | 8,063 |
07-27-2015 11:24 AM Last Post: pack |
User(s) browsing this thread:
