Red top into AE86
10-17-2005, 12:13 PM
Red top into AE86
As title, found a late AE92 with a low mileage engine but I need to know what other parts are needed to fit the engine into my 86 I would prefer not to use the TVIS, can it be removed whilst still keeping the manifold ?
10-17-2005, 01:04 PM
Red top into AE86
You only need the stuff that's already on the ae86 4age to fit the redtop.. And remove a mount and block off a tube. To get rid of TVIS (which wouldnt fit anyway) the best option is to reweld the ae92 manifold. Adapter plates for the bluetop manifold are available, but they are expensive and very inefficient compared to the stock manifold. While your at it fit a bigger throttle body and enjoy some extra power.
10-17-2005, 01:59 PM
Red top into AE86
Well that's good news Thumbs up! What about the wiring and ecu does all of this stay the same too, if yes I'm gonna order the engine right now !!
10-17-2005, 03:29 PM
Red top into AE86
rotational spare Wrote:Well that's good news Thumbs up! What about the wiring and ecu does all of this stay the same too, if yes I'm gonna order the engine right now !!
You will us all the wiring from the ae86.
N P man
10-17-2005, 04:54 PM
Red top into AE86
Thanks everyone, should be fairly straightforward then Thumbs up!
10-20-2005, 03:38 PM
Red top into AE86
N P man
On mine AE86 RedTop Small Port I use harness and ECU from the Redtop integrated (4 days work) with the body electricals.
The intake was cut and rewelded. The water system is from Bluetop with some mods to the lines to pass by the knock sonsor and external oil line.
Not very dificult.
You can use the diagrams from toymods. They are very helpful.
P.S. And don't forget to use 12V supply if using the high impedance redtop injectors. Mine are green - 250cc
AE86 GTS '84 Red Top
  Red top in the ae86 gh0st 25 10,740 08-08-2022 08:43 PM
Last Post: gh0st
  Replacing Top Windscreen Moulding chrisae86 2 2,053 06-18-2022 08:56 PM
Last Post: chrisae86
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 8,061 12-19-2021 11:58 PM
Last Post: gh0st
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,518 04-20-2018 09:14 AM
  Silver top low idle AlexFourTwenty 7 10,222 10-16-2017 10:22 PM
Last Post: AlexFourTwenty
