Reinforced Gearbox mounts/bushings
02-16-2005, 10:05 AM
I've installed a turbocharged 4AGZE in my Corolla. Does any of you know if there is a company that sells reinforced mounts for the gearbox? I'm also looking for reinforced engine mounts. I have been told that I might see as much as 250 ps with approx 15 psi (1 bar) of boost. Wich in turn means that the engine will flex more and the transmission could do with some reinforcement as well..
All help is welcomed, and feel free to suggest other modifications that you feel is necessary in this sort of application. And while I'm at it,- I'm new to this forum! I'll try to get some pictures of the car posted sometime soon. Glad I found this forum, feels like finally I found home sweet home |
02-16-2005, 11:40 AM
Try ebay.com - there were CUSCO engine and tranny mounts.
02-16-2005, 11:51 AM
the TRD and Cusco bushings use a much harder rubber that is why the engine doesn't move that easily. That is better choice if you want your mounts to last much longer.
[email protected] |
02-16-2005, 11:59 AM
I just hope your gearbox will cope with 250ps...I dont think the life expectancy will be very long if you drive it hard (drifting/dragging).
Welcome to the forum BTW.. FABRICA MI DIEM, PVNC! |
02-16-2005, 01:09 PM
TOYCOOLROLLA Wrote:the TRD and Cusco bushings use a much harder rubber that is why the engine doesn't move that easily. That is better choice if you want your mounts to last much longer. Pero bought TRD gearbox bushings, but all that he received were OEM toyota bushings. So, my advice would be, don't buy TRD gearbox mouts. Drifting - best fun you can have in your car with your pants on! |
02-16-2005, 01:31 PM
here you can get the cusco version of bushings http://www.stageoneimports.com/main.pl?s...t=CUSCO-SB
02-16-2005, 01:33 PM
ZaX Wrote:TOYCOOLROLLA Wrote:the TRD and Cusco bushings use a much harder rubber that is why the engine doesn't move that easily. That is better choice if you want your mounts to last much longer. oh...i think he has been cheated on that. Where or from whom did he get the gearbox bushings? [email protected] |
02-16-2005, 02:27 PM
ZaX Wrote:Actually, yes, TRD uses a toyota part number for the gearbox mount so they are standard.TOYCOOLROLLA Wrote:the TRD and Cusco bushings use a much harder rubber that is why the engine doesn't move that easily. That is better choice if you want your mounts to last much longer. The engine mounts are real good, my engine does not move at all |
02-16-2005, 04:26 PM
Hey Norwegian!
Welcome Looking forward to seeing that car! |
02-16-2005, 06:59 PM
s.bjelke Wrote:Hey Norwegian!Yes, sorry, welcome! I am actually kind of from Norway too altough I live here in Belgium Post some pictures of the car |
Lets talk engine mounts | kazi | 6 | 7,744 |
08-31-2017 12:46 PM Last Post: parrot |
Poly vs OEM bushings | Jezza_hr | 5 | 7,613 |
05-14-2014 11:28 PM Last Post: Jezza_hr |
Need urgent help strut mounts. | ditn | 5 | 7,679 |
01-21-2012 03:37 PM Last Post: ditn |
Seat mounts missing! | Bentley | 1 | 3,803 |
05-23-2011 01:22 PM Last Post: Bentley |
Engine Mounts | Bentley | 4 | 5,898 |
04-19-2011 08:07 PM Last Post: Bentley |
