Removal of front seat belts - side trim ?
02-08-2007, 06:42 PM
Ivan141 Wrote:If it is what I think it is, it's a very small piece of plastic where the belt comes though the panel. You can slot it to remove the belt, do it in a place where it wont damage the belt when you put it back and there should be no problem.It is all about the small black/blue/whatevercoloryourinterioris panel around the beld covering where the belt comes from. So if you remove your seatbelts (four point harness? ![]() ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
02-08-2007, 06:50 PM
Thanks banpei, very helpful. Not seen many good pics of 86 interior.
02-10-2007, 05:36 AM
I've dealt with that in a bit of a silly manner:
The seatbelts the car came with were not locking properly, so i took a trip to a scrapyard and got a pair from an old Tercel. Fitting them was a frustration within itself, but the main problem was placing the abovementioned slit-plates. I had to cut them in order to slide the new belts in, because the Tercel's floor mounts had the bolts fixed in them, but in order to take them off the old belts it was no issue - i managed to bend them enough to pass the buckle-head through. Using a screwdriver i bent it enough for the edge of the buckle to hold it open and pivoted the rest out. They are quite flexible like that [at least mine were]. If you're afraid you'll break them - cut them at an upward anlge on one side of the slit - that way you'd be able to slide the belt out and when you place them back it won't be visible unless you look at it from above, in which case I'd be wondering what on earth you're doing sticking your head in the B-column... Cheers and good luck with that. |
Power Steering Removal | 20valver | 2 | 1,036 |
05-19-2024 06:48 PM Last Post: 20valver |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,383 |
Sill removal | totta Crolla | 3 | 2,218 |
09-14-2022 06:30 PM Last Post: totta Crolla |
Bucket seat prices | gh0st | 5 | 2,912 |
01-23-2022 11:44 PM Last Post: AlexKTM |
Rear Seat Belt Question | sleepercivic | 5 | 10,381 |
06-29-2017 09:30 PM Last Post: banpei |
