Removal of front wings
10-27-2004, 08:58 PM
I went out to the garage today and removed the old rusted front wings, but encountered problems, I couldn't remove the two screwes that hold the wings in the bottom, they wheren't stuck, I could turn them and turn them and turn them, but they never came out.
Any ideas of how to remove them? Just cut them off? How are they fixed to the frame? Best Regards, Widar - Who's back at fixing the AE86 after 5 months... ![]() |
10-27-2004, 09:24 PM
I dunno, they broke off on senna's coupe. My guess is that the attachment to the frame is broken, or the bolt has spun and is stripped of its threads. Drill it out I guess.
10-27-2004, 09:29 PM
Yeah drill it out would be my suggestion aswell. I broke one and 3 came out just fine....
Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
10-27-2004, 09:52 PM
mux213 Wrote:Yeah drill it out would be my suggestion aswell. I broke one and 3 came out just fine....Same here, except i call it fenders. ![]() Drifting - best fun you can have in your car with your pants on! |
10-28-2004, 12:49 AM
powertools rock.
I guess this is going to be a problem for mounting then new ones too. ![]() Have you guys seen rivcert/rivnuts ? if so you could replace the screws with some M4 rivnuts and just use new treated bolts so they don't rust up - I guess this is providing the rot hasn't got the main part of the shell. Nice simple solution (maybe). Zax. Where did you get your avatar from - I'd like to make a white Levin to look like mine. Regards Ian. ![]() |
10-28-2004, 09:31 AM
2 ian: i've found it somewhere on the net. You can use mine, and repaintit in photoshop.
Power Steering Removal | 20valver | 2 | 1,052 |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,416 |
Sill removal | totta Crolla | 3 | 2,236 |
09-14-2022 06:30 PM Last Post: totta Crolla |
Why Manual Steering Rack ?? Power Steering Removal | juantonwan | 26 | 45,207 |
Metal removal at rear, opinions | 4000GT | 43 | 45,654 |
01-03-2013 03:28 AM Last Post: 4000GT |
