Ring & pinion ratio.
06-23-2014, 01:32 PM
Hi all.
What would be the best ratio for daily use and sometimes drift and track ? Thanks |
06-23-2014, 03:14 PM
(06-23-2014 01:32 PM)izanagi Wrote: Hi all.depends on the track and what you understand under daily use. most use stock or 4.7 in my case a 4.7 is out of the question as long trips on the motorway are already annoying with the 4.3 due to the high revs. Sent from my Nexus 4 using Tapatalk AE86 ex-daily |
06-23-2014, 03:43 PM
Ok. I think i will buy 4.7. My diff is still whining after changed my bearings so i guess it comes from my ring and pinion.
Any advice about a good brand not too expensive ? |
06-23-2014, 05:43 PM
Ring & pinion ratio. | |||
06-23-2014, 10:11 PM
no no i think its too sort 4.77 for daily use i use in my corolla 4.3 for daily its perfect
06-23-2014, 11:48 PM
06-24-2014, 01:56 AM
(06-23-2014 03:43 PM)izanagi Wrote: My diff is still whining after changed my bearings so i guess it comes from my ring and pinion. The crownwheel and pinion are installed as a set, and create a wear pattern (contact patch) on each other after many years and thousands of kilometres. Once the differential has been dismantled for repair, it can be difficult to get the contact patch exactly matched. That is the usual cause of whining. Same thing applies if you only install a new or used pinion to an existing crownwheel. Worn or loose (lack of preload) pinion bearings can cause whining, and even just a worn out crownwheel and pinion. If the gears appear to be in good condition, you could try adjusting the contact patch, or just put up with the noise, and hope that it settles after a while. Cheers... jondee86 |
06-24-2014, 08:53 AM
(06-24-2014 01:56 AM)jondee86 Wrote:(06-23-2014 03:43 PM)izanagi Wrote: My diff is still whining after changed my bearings so i guess it comes from my ring and pinion. What do you mean by that: If the gears appear to be in good condition, you could try adjusting the contact patch, or just put up with the noise, and hope that it settles after a while. ????? I should set up the ring much closer of the pinion ? With the same method showed in the factory service manual ? |
06-24-2014, 01:16 PM
4.3 is ideal for daily, you will have good acceleration and top speed, with highway drivability.
For higher powered AE86 4.1 is even better. With 4.778 anything above 100 km/h will be annoying. |
06-24-2014, 06:50 PM
(06-24-2014 01:16 PM)Uzelac Wrote: With 4.778 anything above 100 km/h will be annoying. unless you are in a race http://www.ajps.com.au all things ae86 |
ring gear bolts | DJexor | 3 | 5,370 |
12-26-2016 10:56 PM Last Post: totta Crolla |
DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 18,199 |
Checking ring gear diff | izanagi | 3 | 4,955 |
07-09-2014 07:38 AM Last Post: jondee86 |
axle swap time how capable is a std crownwheel and pinion | fax0815 | 32 | 45,786 |
09-26-2013 08:33 PM Last Post: Lajoosh |
Gear end , drive pinion height | filh | 5 | 11,090 |
06-27-2013 12:29 AM Last Post: filh |
