Robokill's Panda Levin Coupe!
03-04-2006, 12:13 AM
Post: #121
Apardal,
he reaso i am going mega squirt is pure perfection related :-) In the future more will change. And i like toying. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
03-16-2006, 12:33 PM
Post: #122
Camshafts are in :-)
clearance [cl] 0.20mm 0.20mm duration [0.1mm+cl] 260° 252° duration [1.0mm+cl] 230° 222° valve lift [cl=0] 9.00mm 8.50mm peak angle 110° 110° timing [1.0mm+cl] 5/45° 41/ 1° lift at TDC [cl=0] 1.65mm 1.25mm So my intake will be 260 degree and exhaust 252. I have done some comparing to the HKS camshafts etc and i noticed a huge difrence. Those camshafts run the same pattern (264 in and out) They have less lift. The clearance on these is just the max of lift and clearance for the 4age. I will be mounting them soon but I still need lots of work before i am gonne test my car. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
03-16-2006, 10:05 PM
Post: #123
robokill, camshaft lobe to shim clearance should be 0,31mm +/-0,03 Exhaust and 0,25mm +/- 0,03 Intake. At least that's what the HKS manual states.
Stock lobe to shim clearances are 0,15-0,25mm Intake and 0,20-0,30mm Exhaust. What brand are yours? Be careful with those exhaust clearances. Tell us how it runs! Best regards! |
03-25-2006, 09:01 AM
Post: #124
Hey Apardal,
We changed my clearence to 0.15mm on all. Brand = Cat Cams I brought my car to the tuner as I had decided I wasn't gonne do my camshafts in myselve. I learned from them the info and how to do this properly and the afternoon went very well. ( brought the car on thursday because the valves need to be completly cold) We build it up and we put on the sanded down and painted valve covers to finish the job.......... To finish the 4a-ge in that case. It seemes that the intake valve cover had some sand in the upper channel above the plate. It destroyed the engine. I had a small drive of around 2 km and just before i hit the highway it died on me. We got it running and decided to do a checkup back at the shop and there it came out. Everything is damaged. Luckily the tuner told me he is able to recover the camshafts. The tuner btw http://www.dbmengineering.nl is very good with the 4age. And i have decided to do a full rebuild now. I will take one of my spare 7 ribbed engines to make a new hart for my AE86. I will keep you all posted on what and how. For now I am just sad! The tuner told me neither he or me could have forseen this. And he is right or not if I would have gatherd more info this would not have happend. Anyways after over 320K of good KM's the engine now dies. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
03-25-2006, 09:28 AM
Post: #125
ja,alleen jammer dat het geen "natuurlijke''dood was
les 1:straalgrit zuigt! motordelen nooit met grit stralen translation: Yes, only ashame it wasn't a natural death lesson 1: sandblasting sand sucks Never sandblast engine parts sr86 completed!!........漂うことのマスター!!!! |
03-25-2006, 12:26 PM
Post: #126
TE71corolla Wrote:ja,alleen jammer dat het geen "natuurlijke''dood wasNow he tells me Robo, like I said on the phone, this sucks major. Its a hard lesson learned Luckely 4age engines aren't too expensive to replace, but that doesn't make it any better. Offcourse your idea of rebuilding an engine from scrap and tuning it right away is a nice choice aswell, allthough a lot more expensive I think its time to invest some money into a parts cleaner Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
03-26-2006, 12:07 PM
Post: #127
Auch. Condoleances
320k is still a lot, so it had a good life. Hope the new engine will be a good one. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
04-01-2006, 09:07 PM
Post: #128
main stuff is orderd and building has begun!
main engine stuff! 40mm crank 7 ribbed lower block Big port head 81.5mm pistons I need to see if the camshafts will be recoverd in that case it will have the following 260 9mm lift intake 252 8.5mm lift exhaust I will add a oil temp sensor + gauge. And i need to see if i let some work done to the head. The intake will be modified and also the exhaust! Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
04-02-2006, 12:37 PM
Post: #129
Sounds like you're out for the serious stuff now.
04-02-2006, 01:17 PM
Post: #130
can't wait to see, hear and feel the end result!
Good luck with building up the engine!! 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
Banpei's two door panda Trueno from Japan | banpei | 6 | 417 |
01-06-2025 08:31 PM Last Post: Eircamae86 |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 15,050 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 161,197 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 739,516 |
Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 40,213 |
04-07-2016 12:15 PM Last Post: mad.matt |
User(s) browsing this thread: 36 Guest(s)
