Robokill's Panda Levin Coupe!
11-08-2006, 07:20 PM
Post: #181
Take that brakeline back to goodridge.. you paid good money for it..the quality should have been better.
11-10-2006, 03:24 AM
Post: #182
ivan its the one on my rear axle the steel one ;-S not the one from goodridge
11-10-2006, 09:59 PM
Post: #183
Oh..that's an easy fix.. take it to any decent garage and they can build you a new one. I made a couple myself for my shitty volvo.
11-11-2006, 09:59 AM
Post: #184
Robokill,
Our friends at lasaulec can wip that up for you for a few euro's, just take the old one with you and tell them to make one with the right length and right ends.
You'll get just a bit of straight brake line with the right ends pressed onto it that you need to bend into shape. But thats easy, I did my whole rear axle myself like that.
09-08-2007, 02:36 PM
Post: #185
Confused Pulled my car from the storage today ...... It doesn't look as bad as I thought it would be but not as good as I hoped for ....
Car defenitly needs a bodywork specialist. I'll be searching one so that when the racer is finished I can drop it of pay money and get it back the way I want it.
For now I will use the hachi again but this time just for the fun stuff. Got some track days comming up. Man I missed that revving engine!
09-09-2007, 08:15 PM
Post: #186
At least its fun to drive again! THe car will get a full overhaul with the use of my 13th month and my holiday savings! next year. The racer will be ready before!!
10-07-2007, 12:12 PM
Post: #187
yesterday I mounted new camshafts. All fun and game but I have the feeling the car doesn't have more power. It probably has less. Though it was really aggressive on the gas its gotten a bit less on that.
It helps me handle the car better though. The nervous act the car had wasn't my way to push it. But for some reason I have the feeling the timing is incorrect. I checked everything but when I set it to 10 btdc it ran shitty so acording the the line on my crankshaft pully I am now at
30+ BTDC I don't know whats wrong with the damn thing but the pulley is from an AW11 so i guess I should mount my AE86 pulley again.
engine runs fine but a bit slow. It could be that the difrent duration of the camshaft makes it slower in the lower PRM range but I cannot feel a high power boost in the upper range. (maybe the ecu can't handle it)
10-12-2007, 10:24 AM
Post: #188
Ok so my ignirion was messed up around 25 degree before top dead center.
Its now correct running on 15 degree and doing some nice speed.
10-15-2007, 08:31 AM
Post: #189
Hurray! Went to a power bench yesterday. (this one should be one of the best power benches in Holland)
I have
132.7 Wheel HP. (i reached 134.8 but the engine was running lean)
I am very happy with the result I will post a picture of the print
10-15-2007, 09:58 AM
Post: #190
Damn thats nice!
  Banpei's two door panda Trueno from Japan banpei 6 517 01-06-2025 08:31 PM
Last Post: Eircamae86
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 15,226 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 161,643 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 741,780 09-03-2017 09:24 PM
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 40,429 04-07-2016 12:15 PM
