Rolling road update
01-05-2008, 01:29 AM
Rolling road update
Rossi Wrote:Cams around the 270-280 area with 8-9mm lift are what i used to run and keep the power low down. Combined wth some headwork which is easy to see where you can improve even with a dremel. i.e matching inlet manifold ports to head ports and gaskets.Can you tell me the likely power output of this + higher compression as above ? An analogue brain in a digital World |
01-05-2008, 01:27 PM
Rolling road update
Depending on the condition of your base engine probably around the 150hp mark combined with a good exhaust system and induction kit.
01-05-2008, 02:03 PM
Rolling road update
The guy that did the rolling road thought the engine was making about 136hp at the flywheel and suggested it was not bad for a standard engine.
He only did a power run, no adjustments were made and I know his rollers are pretty accurate. The thing I'm weighing up of course is the difference between a mildly tuned 16v and a standard 20v Some people suggest the 20v makes a consistent 136hp at the wheels http://66.249.93.104/search?q=cache:WHCV...ring&hl=en (paragraph headed 4age models) While others say 145-150 at the flywheel http://www.billzilla.org/4agmods.htm#115hp (about 3/4 way down page headed 4age 20v engines) Can anyone shed any light on this, has anyone ever put a standard 20v on a dyno ? An analogue brain in a digital World |
Sparco chrono road seat rails | stratosTRD | 6 | 7,855 |
09-03-2011 07:32 PM Last Post: stratosTRD |
4AGE ITB's Rolling Road session | byd1380 | 14 | 16,963 |
01-19-2008 04:13 PM Last Post: ghostgrunt |
Rolling fenders??? | ts@n@k@s | 7 | 10,160 |
06-27-2007 05:26 PM Last Post: momo-gt |
Discussion: blacktop 20v: the road beyond 200HP | 86er | 19 | 24,046 |
02-21-2007 07:06 AM Last Post: BenR |
Discussion: blacktop 20v: the road beyond 200HP | 86er | 1 | 6,810 |
01-17-2007 06:25 PM Last Post: 86er |
