S13 Hubs on ae86 ??
09-04-2013, 11:40 PM
S13 Hubs on ae86 ??
A weird question.
By changing the hub bearing to ae86/ke70/ke30 on the s13 hubs it would be possible to put it on right ? Technically speaking it should work. Has anyone the possibility to measure a ae86 hub,bearings and the s13 hub ?? Would be awesome. Should work with any hub out there for RWD cars. as long as the bearing size is the same. Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
09-08-2013, 10:28 AM
S13 Hubs on ae86 ??
No one ? I think its a good way to find brake upgrades and so on.
09-08-2013, 11:06 AM
S13 Hubs on ae86 ??
complete front struts, yes
09-08-2013, 12:16 PM
S13 Hubs on ae86 ??
Hi. For hubs swap You must use front struts from s13. Lower control arms-> beacuse steering knuckle from s13 has different diameter(lower ball joint in ae86 has lless diameter). Camber plates or different upper mounts. Tie rod end from s13 and adapter between tie rod end(s13) and tie rod(ae86).
KAE70--> http://www.youtube.com/watch?v=VJasjMGVd7k Ae86 daily drift car rebuild |
09-08-2013, 05:40 PM
S13 Hubs on ae86 ??
I mean the toyota bearings pressed into nissan hubs if same diameter... not complete swap. its just the bearings that has contact with the spindles.
![]() Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
09-08-2013, 05:58 PM
S13 Hubs on ae86 ??
for that kind of swap, you need both the small and big bearing to have the same outer ring diameter in the ae86 and s13 hub, and also need to be the same distance between them, not to mention, matching sealing diameter. i dont see one percent chance for this.
youre better off making your own hubs if you want different pcd, width or barke solution. though i dont get why anyone need all these, the ae86 community already has moultiple solutions for different needs. |
09-08-2013, 06:09 PM
S13 Hubs on ae86 ??
just asking if anyone has checked
09-08-2013, 10:48 PM
S13 Hubs on ae86 ??
i would stick with ae86 parts,no sweating over geometry.
There are plenty enough brake updates from normal to rx7 to ap racing braking options. |
09-09-2013, 12:16 AM
S13 Hubs on ae86 ??
Quote:I was talking with my local BC dealer the other day, and he showed Just saying... there are a lot of options available, just depends on how much work you want to do yourself, and the risks you are prepared to take. Cheers... jondee86 |
09-09-2013, 12:26 AM
S13 Hubs on ae86 ??
the bearings. first of all i can't find any hubs anywhere to the ae86. im gonna put on my ke30 mint. all i want are the dimensions of the ae86 bearings and s13 ones. like I said before. i dont want any suspension parts from nissan just hubs if it were to work. I can't seem to find info about the bearing dimensions. thanks
Billet 5X114.3 hubs adds 30mm offset | 4000GT | 0 | 3,712 |
01-30-2015 06:40 AM Last Post: 4000GT |
S13 Front conversion help (S14/S15?) | 4000GT | 6 | 9,133 |
11-21-2014 06:55 PM Last Post: asyrigos |
Alloy hubs versus stock | 4000GT | 20 | 20,097 |
10-10-2014 12:57 AM Last Post: robokill |
SR20DET (S13) gearbox shifting issues in AE86 | heshan | 8 | 11,635 |
07-22-2014 01:07 PM Last Post: heshan |
S13 Front brakes in AE86 rear | heshan | 25 | 29,495 |
02-01-2014 12:37 PM Last Post: heshan |
