S2000 Cluster in 86 Corolla ?? pro's plz
07-25-2010, 02:09 PM
So I tried getting the 86 fuel level sensor working on the s2000 cluster as its about 20ohms difference. It picks up here and there and as I suspect the 86 sensor is too unreliable. Hence, chopped, grinded, filed my modified 86 one with a s2000 sender and works like a charm (on the table . Measurements and throw arm look pretty good as well.
07-26-2010, 06:10 PM
Some update for me here:
http://www.aeu86.org/viewtopic/ae86/p/128965#128965 I will let you know how it work |
07-31-2010, 07:48 PM
S2000 Cluster in 86 Corolla ?? pro's plz | |||
08-01-2010, 12:19 PM
Good work.
Let me know if you need the Temperature Gauge converter as I can scale down my design for the temperture converter - programmed to toyota ECT and triggered with specified temperatures of your liking. Here's my converter design board v1.0: (sent off for PCB manufacturering) |
08-01-2010, 12:24 PM
Remember to hookup the VSS input into your SPD signal to keep your ECU happy.
08-01-2010, 12:37 PM
Pretty cool!! i wish i had thad knowledge
http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
08-01-2010, 01:46 PM
thanhngo Wrote:Remember to hookup the VSS input into your SPD signal to keep your ECU happy.Actualy I have a Megasquirt II so I don't need to hookup the VSS (and anyway I have a 16v not a 20v so my sock ECU don't need SPD signal) I'm building Coil On Plug setup and the Denso COP seem to have tach signal output. I don't know what kind of signal is, but I hope it will be 12v square wave |
08-01-2010, 01:50 PM
For Denso COPs' 5V on falling edge to IGT.
IGT: IGf: My circuit actually runs off Denso COP's IGf signal Can't the MS output the rpm/tacho signal for you? (JDM 16V ECU needs still needs SPD signal I believe) ennieb: time and persistance Actually found building this fun and a learning experience. |
08-01-2010, 01:56 PM
thanhngo Wrote:5V on falling edge to IGT.OK. Yes MS have programmable outputs and tach is one of the options but if I could make this directly from COP that will be simpler that programing output on MS. |
08-01-2010, 02:03 PM
I didn't work for me but don't let me stop you from trying.
In the end I had to capture and reprocess the signal. Make sure you include a RC filter as the line gets noisy. |
EUDM gauge cluster | banpei | 22 | 4,342 |
EUDM cluster revelations | banpei | 1 | 1,250 |
06-23-2023 09:11 AM Last Post: r.ave |
Custom Dash Cluster | kazi | 14 | 20,042 |
EDM GT-S Cluster, PWR light VSV? | Rascal21 | 1 | 3,963 |
06-25-2017 08:00 PM Last Post: Rascal21 |
HELP! need AE85 lisse/lime cluster diagram | AE86_DRIFTER_ | 0 | 3,509 |
06-27-2016 11:38 PM Last Post: AE86_DRIFTER_ |
