S2000 Cluster in 86 Corolla ?? pro's plz
07-25-2010, 02:09 PM
So I tried getting the 86 fuel level sensor working on the s2000 cluster as its about 20ohms difference. It picks up here and there and as I suspect the 86 sensor is too unreliable. Hence, chopped, grinded, filed my modified 86 one with a s2000 sender and works like a charm (on the table Smile. Measurements and throw arm look pretty good as well.
[Image: AEU86 AE86 - S2000 Cluster in 86 Corolla ?? pro's plz]
07-26-2010, 06:10 PM
Some update for me here:
http://www.aeu86.org/viewtopic/ae86/p/128965#128965
I will let you know how it work Wink
07-31-2010, 07:48 PM
Speedo -> OK Tongue
http://vimeo.com/13784810
Now it need to be calibrated on the car Cool
08-01-2010, 12:19 PM
Good work.
Let me know if you need the Temperature Gauge converter as I can scale down my design for the temperture converter - programmed to toyota ECT and triggered with specified temperatures of your liking.
Here's my converter design board v1.0: (sent off for PCB manufacturering)
08-01-2010, 12:24 PM
Remember to hookup the VSS input into your SPD signal to keep your ECU happy.
08-01-2010, 12:37 PM
Pretty cool!! i wish i had thad knowledge
http://bruutt.blogspot.nl/
08-01-2010, 01:46 PM
thanhngo Wrote:Remember to hookup the VSS input into your SPD signal to keep your ECU happy.
Actualy I have a Megasquirt II so I don't need to hookup the VSS Tongue
(and anyway I have a 16v not a 20v so my sock ECU don't need SPD signal)
I'm building Coil On Plug setup and the Denso COP seem to have tach signal output. I don't know what kind of signal is, but I hope it will be 12v square wave Smile
08-01-2010, 01:50 PM
For Denso COPs' 5V on falling edge to IGT.
IGT:
IGf:
My circuit actually runs off Denso COP's IGf signal Tongue Can't the MS output the rpm/tacho signal for you?
(JDM 16V ECU needs still needs SPD signal I believe)
ennieb: time and persistance Smile Actually found building this fun and a learning experience.
08-01-2010, 01:56 PM
thanhngo Wrote:5V on falling edge to IGT.
OK.
Yes MS have programmable outputs and tach is one of the options but if I could make this directly from COP that will be simpler that programing output on MS.
08-01-2010, 02:03 PM
I didn't work for me but don't let me stop you from trying.
In the end I had to capture and reprocess the signal. Make sure you include a RC filter as the line gets noisy.
  EUDM gauge cluster banpei 22 5,560 08-15-2023 10:48 PM
  EUDM cluster revelations banpei 1 1,413 06-23-2023 09:11 AM
Last Post: r.ave
  Custom Dash Cluster kazi 14 21,061 10-24-2017 09:05 PM
Last Post: kazi
  EDM GT-S Cluster, PWR light VSV? Rascal21 1 4,187 06-25-2017 08:00 PM
Last Post: Rascal21
  HELP! need AE85 lisse/lime cluster diagram AE86_DRIFTER_ 0 3,645 06-27-2016 11:38 PM
Last Post: AE86_DRIFTER_
