SARD oil pressure gauge - help
05-27-2010, 11:53 AM
[Image: AEU86 AE86 - SARD oil pressure gauge - help]
Bought as used on ebay a while ago. I've got the gauge itself, the sensor and the harness for the sensor, but no manual and main harness. Wrote emails for all known SARD distributor asking for user or installation manual to BUY, got only one response, describing their business policy not to support secondhand products. So, I'm after any suggestion for wiring this unit... It has a 3 point connector for the sensor harness, and a 6 point connector for the main harness. We're able to recognise three out of these 6, ground, switched 12V and lights, so the gauge is working, but not fully functional. The additional 3 point is for the constant 12V for the memory function and two output, one for the datalogger (sensor output) and an other for the warning output. Unfortunately without these pins the unit are not functioning correctly, for example the warning LED are on, and can't be switched off..a little bit annoying.
So, to keep the long story short, if somebody has any idea or manual or how to wire, or knows somebody who using it with success, it will be really appreciated.
http://www.ae86.hu
05-27-2010, 01:39 PM
Little bit of google found this:
Orange: 12v Permanent Battery Live for the memory function
Red: 12v Live ignition switched on
Black: Earth/Ground
Yellow: Illumination connect into lights on switch
Green: Sensor Output
Brown: Warning Light Output
Works ?
05-27-2010, 02:02 PM
Yep, this is what I found as well at the rhdjapan blog. But the order of the pins not the same as here and the pins are not colored, but thanks anyway.
http://www.ae86.hu
  EUDM gauge cluster banpei 22 5,638 08-15-2023 10:48 PM
  Oil leaks - Help Bojack 4 5,884 10-19-2018 01:34 PM
Last Post: Dave W
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,749 08-19-2018 12:08 PM
Last Post: AlexKTM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 8,047 12-06-2017 06:48 PM
  Analog gauge cluster tech Ivan141 33 44,138 01-31-2016 11:06 PM
