SR Levin hatch from Prague, CZ
12-22-2006, 10:07 AM
![]() 86ers.org AE86 x GXE10 |
12-22-2006, 12:30 PM
Nice start!!
Looks like someone did a little rust repair on it before and the worst is already gone. Don't see much serious bits left over or did you just not take pictures of that yet? ![]() Anyways great work! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
12-22-2006, 05:25 PM
12-22-2006, 08:03 PM
Are you sure you're looking for the right bolts? You shouldn't try to unscrew the bumper supports from the bumper but rather unscrew the bumper supports from the car.
On my car and the E9 (and I guess it should be the same for the AE86???) it is pretty easy. There's two rubber caps on each side of the spare wheel under the carpet that you have to take out. Under each cap there is a bolt that you have to take out. If you have the small bolts and supports on the rear fender out you can just shift the whole bumper backwards. |
12-22-2006, 08:08 PM
These are the caps I mean...
12-22-2006, 09:24 PM
12-22-2006, 11:57 PM
Cece,
valis jako blazen! Pustil ses do toho po hlave!! Drzim pesti. Vcera jsem dostal pruziny Apex z Holandu a pomalu se chystam na poradnou opravu. Snad to pujde hladce. Doufam, ze se nekdy setkame. Man, you really rule! You went into this really fast!! Good luck. Yesterday I received Apex springs and start to prepare for big renovation. Hopefully it will go smooth. I hope we will meet someday. O. Merry X-mas! |
12-23-2006, 12:20 AM
12-23-2006, 12:24 AM
12-23-2006, 12:30 AM
its not hard to remove the spoiler. you just need to remove about 8 screws if I am not mistake. this mean you also need to fix all the holes if you remove the hole. I am thinking to do so, but I still can't make a choice till now
![]() 1985 AE86 (ハチロク) Levin - Summer time daily driver |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 18,014 |
86er Levin Hatch from Germany | ArToAE86 | 19 | 19,493 |
01-24-2018 10:35 PM Last Post: ArToAE86 |
OST-026: "My White Hatch" | oldeskewltoy | 49 | 65,112 |
07-03-2014 11:56 PM Last Post: oldeskewltoy |
White Kouki Trueno Hatch, 20V BT, FC3S brake, Watanabe MG, | asw | 47 | 67,007 |
04-08-2011 04:11 PM Last Post: asw |
can any post sum pics ov carbon hatch/bootlid | irish ae86 | 4 | 8,370 |
03-26-2011 07:15 PM Last Post: irish ae86 |
