SR Levin hatch from Prague, CZ
12-23-2006, 01:37 AM
if it fails you can always put a trd wing on
12-23-2006, 01:59 AM
hey guys if you find any more hachi's in tjech plz let me know i'll come pick em up ;-)
N1 project start always good to start stipping! Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
12-23-2006, 09:54 AM
86ers.org AE86 x GXE10 |
12-23-2006, 10:40 AM
oldskull Wrote:its not hard to remove the spoiler. you just need to remove about 8 screws if I am not mistake. this mean you also need to fix all the holes if you remove the hole. I am thinking to do so, but I still can't make a choice till now I hope they're fitted more decently then mine... On mine there's bolts with square heads that are molded inside the plastic so you would only have to unscrew some nuts on the inside... Unfortunately, on half of the bolts the square heads do not stick in the square plastic holes in the spoiler that should keep them from turning arround while you're trying to get the nuts of... |
12-23-2006, 12:12 PM
Sometimes the rust on the bolts causes the plastic pads they are screwed into to break off.(there are some plastic mounts with a threaded metal clamp in there). Just thought I'd warn you about that. It can be fixed though.
When doing a project I would remove the spoiler anyway.. imagine how dissapointed you would be if the rust came from under your spoiler to ruin your new paintjob later on. FABRICA MI DIEM, PVNC! |
12-23-2006, 12:23 PM
Ivan141 Wrote:When doing a project I would remove the spoiler anyway.. imagine how dissapointed you would be if the rust came from under your spoiler to ruin your new paintjob later on. I am thinking the same too 1985 AE86 (ハチロク) Levin - Summer time daily driver |
12-23-2006, 12:46 PM
Ivan141 Wrote:Sometimes the rust on the bolts causes the plastic pads they are screwed into to break off.(there are some plastic mounts with a threaded metal clamp in there). Just thought I'd warn you about that. It can be fixed though. That's a better way of describing what I meant :-) You're right about removing it anyway though |
12-23-2006, 04:41 PM
12-23-2006, 05:07 PM
12-26-2006, 08:41 PM
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 15,099 |
86er Levin Hatch from Germany | ArToAE86 | 19 | 16,567 |
01-24-2018 10:35 PM Last Post: ArToAE86 |
OST-026: "My White Hatch" | oldeskewltoy | 49 | 58,957 |
07-03-2014 11:56 PM Last Post: oldeskewltoy |
White Kouki Trueno Hatch, 20V BT, FC3S brake, Watanabe MG, | asw | 47 | 60,087 |
04-08-2011 04:11 PM Last Post: asw |
can any post sum pics ov carbon hatch/bootlid | irish ae86 | 4 | 7,536 |
03-26-2011 07:15 PM Last Post: irish ae86 |
