SR Levin hatch from Prague, CZ
12-23-2006, 01:37 AM
if it fails you can always put a trd wing on Big Grin
[Image: AEU86 AE86 - SR Levin hatch from Prague, CZ]
12-23-2006, 01:59 AM
hey guys if you find any more hachi's in tjech plz let me know i'll come pick em up ;-)
N1 project start always good to start stipping!
12-23-2006, 09:54 AM
Hurray!
86ers.org
AE86 x GXE10
12-23-2006, 10:40 AM
oldskull Wrote:its not hard to remove the spoiler. you just need to remove about 8 screws if I am not mistake. this mean you also need to fix all the holes if you remove the hole. I am thinking to do so, but I still can't make a choice till now Tongue
I hope they're fitted more decently then mine... On mine there's bolts with square heads that are molded inside the plastic so you would only have to unscrew some nuts on the inside... Unfortunately, on half of the bolts the square heads do not stick in the square plastic holes in the spoiler that should keep them from turning arround while you're trying to get the nuts of...
12-23-2006, 12:12 PM
Sometimes the rust on the bolts causes the plastic pads they are screwed into to break off.(there are some plastic mounts with a threaded metal clamp in there). Just thought I'd warn you about that. It can be fixed though.
When doing a project I would remove the spoiler anyway.. imagine how dissapointed you would be if the rust came from under your spoiler to ruin your new paintjob later on.
12-23-2006, 12:23 PM
Ivan141 Wrote:When doing a project I would remove the spoiler anyway.. imagine how dissapointed you would be if the rust came from under your spoiler to ruin your new paintjob later on.
I am thinking the same too Smile
12-23-2006, 12:46 PM
Ivan141 Wrote:Sometimes the rust on the bolts causes the plastic pads they are screwed into to break off.(there are some plastic mounts with a threaded metal clamp in there). Just thought I'd warn you about that. It can be fixed though.
That's a better way of describing what I meant :-) You're right about removing it anyway though
12-23-2006, 04:41 PM
Hurray!
86ers.org
AE86 x GXE10
12-23-2006, 05:07 PM
Hurray!
86ers.org
AE86 x GXE10
12-26-2006, 08:41 PM
Hurray!
86ers.org
AE86 x GXE10
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 15,247 10-07-2018 09:45 PM
  86er Levin Hatch from Germany ArToAE86 19 16,731 01-24-2018 10:35 PM
Last Post: ArToAE86
  OST-026: "My White Hatch" oldeskewltoy 49 59,289 07-03-2014 11:56 PM
  White Kouki Trueno Hatch, 20V BT, FC3S brake, Watanabe MG, asw 47 60,438 04-08-2011 04:11 PM
Last Post: asw
  can any post sum pics ov carbon hatch/bootlid irish ae86 4 7,556 03-26-2011 07:15 PM
Last Post: irish ae86
