Silvertop ECU P/N
05-18-2009, 11:43 AM
Silvertop ECU P/N
I found a ECU with toyota P/N 89661-1A870 and DENSO P/N 175300-0631.
Also its pin connections are 26P/16P/22P. On the cover it says 4A-G A/T. Can I use this ECU on a Silvertop engine? (Even with some minor modifications) Appreciate if any one could help me out. |
08-20-2009, 12:47 PM
Silvertop ECU P/N
Can any one tell me the best OEM ECU that came for the Blacktop.
I'm planning to install the engine in my AE85 with a T50 Gearbox. I've notice that they say A/T ECUs rev 400rpm more before redline. Following are the P/Ns for the BT, 89661-1A470 (A/T) 89661-1A480 (A/T) 89661-1A490 (A/T) 89661-1A660 ?? 89661-1A860 (M/T) 89661-1A880 (A/T) 89661-1E090 (M/T) 89661-1E100 (A/T) What are the differences? |
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 2,966 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 14,099 |
20v silvertop idle issue | AlexFourTwenty | 3 | 5,395 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 6,081 |
02-20-2016 11:48 AM Last Post: Bean |
20v silvertop exhaust manifold on 16v 2nd version tvis motor | Apsogos | 17 | 23,105 |
