Silvertop Headgasket?
01-05-2009, 01:13 PM
I have recently had alot of trouble with my silvertop conversion, I broke a valve spring and bent a inlet valve and guide. I had the valve springs/stem oil seals replaced, parts took nearly two months to arrive fron toyota. I then fitted the head and took the car to the rolling road, and turns out the new valve and follower was sticking, boo hiss. I have pulle dteh head off and have it fixed now. but I need to get a new head gasket ASAP, just wondering of the 16v 4AGE gasket fits, as it is the same block. I cant wait 2 months again from toyota.
Cheers
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
01-05-2009, 02:24 PM
According to Phil Sherwood they are different:
[Image: AEU86 AE86 - Silvertop Headgasket?]
top one is 20v and bottom one is 16v.
Passracing does sell a full gasket set for the 20v:
http://store.autosportsupplies.com/merch...y_Code=TFP
Try to contact SYM, maybe they also sell them seperately. Wink
01-05-2009, 06:02 PM
Managed to get one through toyota, should have it by the end of the week. Thanks
Ivan
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 3,071 05-26-2024 07:40 PM
Last Post: totta Crolla
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,142 07-18-2019 03:52 PM
  20v silvertop idle issue AlexFourTwenty 3 5,404 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 6,105 02-20-2016 11:48 AM
  20v silvertop exhaust manifold on 16v 2nd version tvis motor Apsogos 17 23,183 11-22-2012 11:15 PM
Last Post: Apsogos
User(s) browsing this thread:
