Silvertop Oil cooler.
06-26-2008, 02:42 AM
Does a silvertop have a oil cooler as standard? My old 16v largeport had one, should I try and fit it to the silvertop?
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
06-27-2008, 05:02 PM
The stock 20V doesn't have an oil cooler. Fitting one might be a good idea dependning on how you use it Wink I want to fit one to my blacktop, though... The stock unit isn't great. I want to go with full flow setup with a thermostat Smile
[Image: AEU86 AE86 - Silvertop Oil cooler.]
06-27-2008, 07:17 PM
Ivan, the 4age has a setup on the oilfilter and a return plug in the oilsumppan.
You could recreate this on the silvertop whitout problems.
06-28-2008, 10:24 AM
It's the same as with the 4AGZE. You can find a discussion about how to fit it here:
http://www.aeu86.org/viewtopic/mocal-oil...red/t/6861
And here how to fit them:
http://www.aeu86.org/viewtopic/ae86/p/92568#92568
06-28-2008, 12:36 PM
and if you want aditional Info, Just ask me !! (like partnumbers or so.. or where to buy.. )
Cheers
Roel
Gtsi-R
"Trust me, I was an engineer"
06-28-2008, 11:14 PM
No need for an oil cooler on those motors unless you live in a desert.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 2,975 05-26-2024 07:40 PM
Last Post: totta Crolla
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 57,833 11-18-2022 02:19 PM
Last Post: FanIsHere
  Oil cooler totta Crolla 0 1,675 07-25-2021 03:25 PM
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,111 07-18-2019 03:52 PM
  20v silvertop idle issue AlexFourTwenty 3 5,396 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
