Silvertop velocity stacks - trumpets?
08-13-2009, 11:08 AM
I have 20v silvertop, the standard trumpets/airbox doesn't fit under the bonnet. Does anyone know where to get some short aftermarket ones, pref in Europe/ uk. I run a standalone, so dont use the AFM.
Cheers
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
08-13-2009, 12:55 PM
Ebay (T3):
http://cgi.ebay.com/ebaymotors/Red-Veloc...ccessories
http://cgi.ebay.com/ebaymotors/Silver-Ve...ccessories
Tweakit:
http://www.tweakit.net/shop/product_info...ts_id=1008
None of them in Europe though..
08-14-2009, 02:02 PM
Cheers for that, just need to check sizes and make sure they will fit under the air filter.
Thanks
Ivan
08-14-2009, 09:15 PM
you can get several sizes for the ST at tokyoseven.com from SPTEC
08-15-2009, 06:21 AM
Note that the length of the velocity stacks has an important influence on the engine characteristics.
http://www.sg-rallyesport.de
08-18-2009, 04:36 AM
Also be aware of the proximity of the brake booster. This will limit your available length, and LHD's don't have this restriction.
08-20-2009, 11:35 AM
Thanks Nomuken,
I haven't seen that site before.
Does anyone have any experience with using different stack lengths? I was running without any Blush Just a pipercross filter. The shorter the better for me to fit under the filter. Also bottom end power would be good.
Thanks
Ivan
08-20-2009, 02:58 PM
If you are using the pipercross airbox, they say you can use trumpets with a maximum length of 45mm. But you def. should use some trumpets, they will improve the airflow drastically
08-24-2009, 08:18 AM
If your engine characteristics are such that there is more available bottom end than you're currently getting, then generally, a longer trumpet will move the biase this way. Ideally make an adjustable length intake (ie. 2 snug but sliding bits of piping with lengths marked on them) and put it on a dyno.
08-24-2009, 02:36 PM
Chrisso Wrote:Also be aware of the proximity of the brake booster. This will limit your available length, and LHD's don't have this restriction.
i had them on my last Ae86 20V blacktop, and the last trumpet was slighty shaven/cut so that it did not clash with the braker Booster.
Coupes, hoops and loops
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 6,246 05-26-2024 07:40 PM
Last Post: totta Crolla
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 16,450 07-18-2019 03:52 PM
  20v silvertop idle issue AlexFourTwenty 3 6,533 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 6,983 02-20-2016 11:48 AM
  20v silvertop exhaust manifold on 16v 2nd version tvis motor Apsogos 17 26,166 11-22-2012 11:15 PM
Last Post: Apsogos
