Some parts that i sell
07-27-2006, 10:46 AM
i get asked quite frequently what all parts do i sell
well i made a list took me a few hours to do so
but i think it will probably help some one out who is looking for something
basically i took all the posts of parts for sale i have up on club 4ag and combined them
happy reading
BTW all the prices are in USD
New Parts for sale
CLUTCHES
TOYOTA
4AGE (200mm) starting at 295
4AGE (212MM) starting at 415
4AGZE starting at 369
4AGE for W58 Trans starting at 325 (200mm)
4AGE for W58 Trans starting at 425 (212mm)
3SGTE 90~95 SW20 Turbo starting at 375
7MGTE starting at 520
3TC 2 door 315
3TC 4 door 270
SCION
TC Starting at 315
NISSAN
KA (SOHC & DOHC) starting at 365, (DOUBLE DIAPHRAM NOW AVAIALABLE!)
SR20DET starting at 375 (DOUBLE DIAPHRAM NOW AVAIALABLE!)
CA18DET Starting at 311
RB25DET Double Diaphragm (TBA)
MAZDA
Miata 1.6 starting at 300
Miata 1.8 starting at 345
NA FC3S starting at 325 (zenki) 345 (kouki)
Turbo II FC starting at 410
FD RX7 starting at 650
MISTUBISHI
Gallant VR-4 starting at 350
EVO starting at 875
SUBARU
WRX starting at 775
HONDA
S2K starting at 850
Ford
Focus starting at $550
TRANSMISSION REBUILD KIT
TOYOTA
1985~87 COROLLA GTS RWD
T50 TRANSMISSION 5MT 350
W55 TRANSMISSION 5MT 350
FLYWHEEL
TOYOTA
4AGE 200MM 250
7AGE 200MM 250
DRIVESHAFT (1 PIECE LIGHT WEIGHT STEEL)
TOYOTA
1985~87 COROLLA GTS RWD 350
BRAKE PADS
TOYOTA
1985~87 COROLLA GTS RWD METALIC PADS
FRONTS 45
REARS 45
MK3 SUPRA NA METALIC PADS
FRONTS (TBA)
REARS (TBA)
MK3 SUPRA TURBO METALIC PADS
FRONTS (TBA)
REARS (TBA)
MK4 SUPRA NA METALIC PADS
FRONTS (TBA)
REARS (TBA)
MK4 SUPRA TURBO METALIC PADS
FRONTS (TBA)
REARS (TBA)
1985~89 MR2 METALIC PADS
FRONTS (TBA)
REARS (TBA)
91~96 MR2 METALIC PADS
FRONTS (TBA)
REARS (TBA)
NISSAN
1989~97 240SX 4 LUG METALIC PADS
FRONTS (TBA)
REARS (TBA)
1989~97 240SX 5 LUG METALIC PADS
FRONTS (TBA)
REARS (TBA)
1989~97 300ZX NA METALIC PADS
FRONTS (TBA)
REARS (TBA)
1989~96 300ZX TURBO METALIC PADS
FRONTS (TBA)
REARS (TBA)
BRAKE ROTORS
TOYOTA
FRONTS 35
REARS 35
MK3 SUPRA NA
FRONTS (TBA)
REARS (TBA)
MK3 SUPRA TURBO
FRONTS (TBA)
REARS (TBA)
MK4 SUPRA NA
FRONTS (TBA)
REARS (TBA)
MK4 SUPRA TURBO
FRONTS (TBA)
REARS (TBA)
1985~89 MR2
FRONTS (TBA)
REARS (TBA)
91~96 MR2
FRONTS (TBA)
REARS (TBA)
NISSAN
1989~97 240SX 4 LUG
FRONTS (TBA)
REARS (TBA)
1989~97 240SX 5 LUG
FRONTS (TBA)
REARS (TBA)
1989~97 300ZX NA
FRONTS (TBA)
REARS (TBA)
1989~96 300ZX TURBO
FRONTS (TBA)
REARS (TBA)
SHOCKS
TOYOTA
TOKICO HTS
FRONTS 275
REARS 275
TOKICO HP
FRONTS 100
REARS 85
SPRINGS (TRD JAPAN)
TOYOTA
FRONTS 155 (MANY DIFFRENT RATES AVAILABLE)
REARS 155 (MANY DIFFRENT RATES AVAILABLE)
WHEELS
(SET OF 4 WHEELS) 4x114.3 PCD
KONIG REWINGS (15x7 ZERO OFFSET) 500
SPORT MAX 002 (15X8 ZERO OFFSET) 425
VOLK TE37 (14X7 ZERO OFFSET) 1400
VOLK TE37 (15X7 ZERO OFFSET) 1600
TIRES
(SET OF 4 TIRES)
DUNLOP FM901'S 195/50 15 $299
DUNLOP FM901'S 195/55 15 $319
FALKEN ZIEX ???
FALKEN AZENIS ???
YOKOHAMA ES100 195/50 15 $334
JAPANESE OEM
AE86 KOUKI TRUENO PARTS
Kouki front Skin $430
Kouki front brackets (L+R) $134
Kouki front bumper lamps (L+R) $165
Kouki front Grill $57
Kouki emblem $29
Kouki Black limited Emblem $34
Kouki Rear skin $224
Kouki Rear Bumper Brackets $114
AE86 KOUKI LEVIN PARTS
Kouki Levin hood OEM $450
Kouki levin fender R OEM $575
Kouki levin fender L OEM $250
Kouki levin front bumper OEM $250
Kouki levin Headlamp L $325
Kouki levin Headlamp R $325
Kouki Levin front bumper bracket L $75
Kouki Levin front bumper bracket R $75
Kouki Levin front bumper lamp L $100
Kouki Levin front bumper lamp R $100
Kouki Levin front grill $150
Kouki Levin corner lamp L $125
Kouki Levin corner lamp R $125
Kouki Levin fog lamp L $125
Kouki Levin fog lamp R $125
FRP Levin fenders $400 (pair)
FRP levin Hood $400
CF levin fenders $550 (pair)
CF levin hood $550
OEM PARTS
CLIMTAE CONTROL (STICKER ONLY) 15
CLOCK BEZEL 15
IGNITON CYCLINDER W/ 2 KEYS 90
FRONT CALIPER REBUILD KIT 20
REAR CALIPER REBUILD KIT 20
CAT BACK EXHAUST 120
INNER TIE RODS (MOOG) 100
OUTTER TIE RODS (MOOG) 100
TRANSMISSION MOUNT 100
CAT CONVERTER 125
EX MANIFOLD STUDS 6 EACH
EX MANIFOLD NUTS 4 EACH
TRD
HEAD GASKET 60
4~1 HEADERS 425
ENGINE MOUNTS (2 PIECES) 110
BUSHING KIT 375
SHIFT KNOB BALL TYPE 30
FRONT SWAY BAR 180
DISTRIBUTOR HEAT SHIELD
1985~87 COROLLA GTS RWD 45
SILICONE INTAKE HOSE
1985~87 COROLLA GTS RWD 55
USED PARTS FOR SALE
1985~87 COROLLA GTS RWD (4AGE)
Drivers door glass 15 bucks each
Passangers door glass 15 bucks each
rear coupe glass 40 bucks each
rear hatch glass 50 bucks each
ZENKI LEVIN POP UP GRILL 100
FENDER LAMPS 10 (PER PAIR)
TAIL LAMPS USA TYPE 15 EACH
WATER PUMP REAR HOUSING 25
WATER LINES 20
THERMOSTAT NECK 10
UPPER RADIATOR PIPE 10
OPEN DIFFERENTIAL GEARS ZENKI AND KOUKI 25
OIL FILTER SANDWICH PLATE (FOR OIL COOLER) 25
ALTERNAOTR BRACKET 45
IGNITION CYCLIDER W/ KEY 25
AE101 IGNITOR 100
AE11 IGNITOR 100
CRANK PULLEY 75
TVIS BUTTERFLIES 50
STARTER 25
ALTERNATOR 50
BLUETOP CYCLINDER HEAD 50
T50 TRANSMISSION NO BELLHOUSING 75
ENGINE HARNESS 125
UNDERDASH HARNESS 125
REAR HARNESS 75
FUSE BOX/ALTERNATOR HARNESS W/ FUSE BOX 100
IGNITOR 25
DISTRIBUTOR 50
TIMING BELT GEAR 10
WATER PUMP PULLEY 25
INTAKE MANIFOLD 200
O/S 2MM THROTTLE BODY 100
REDTOP FUEL RAIL 75
CLUTCH HARD LINE 75
STRUT BARS 50
CIRCUT OPENEING RELAY 20
GAUGE CLUTSTER 50
SR5 GAUGE CLUSTER 10
FLYWHEEL (RESURFACED) 45
TO BEARING COLAR 10
CLUTCH FORK 10
EGR SETUP 100
HOOD 35
DOOR 35
MIRRORS 15 (EACH)
SPEEDO CABLE 25
STEERING RACK 75
STEERING COLUMB 50
AIR FLOW METER 45
INJECTORS 10 EACH
EGR BOLT 10
Thanks for looking
Max
*admin edit* just removed the post in wrong section bit in the titel. Max remove this edit when you wish, just to let you know I edited the titel for youBig Grin
[email protected]
07-27-2006, 03:06 PM
Hey max,
hehe, well you are in the buy section while you are selling, and you are a commercial garage of sorts, so..Big Grin
I'll transfer this to the commercial section and I'll see if I can give you full access there (with banpei on vacation I need to figure some things out he usually doesSmile) But the rights are only for starting new threads sso...
07-27-2006, 10:40 PM
Max the mirrors are the electric-powered ones ?
07-27-2006, 11:25 PM
yea i have some extra POWER mirrors
most people dont like them though because they shake so badly
thats why we like SR5 cheapie manual mirrors
no shaking you eyeballs to death when you look to change lanes
Max
[email protected]
07-28-2006, 12:01 PM
How much for powered and non-powered ones with shipping costs to GREECE?
07-28-2006, 01:39 PM
Hi,
Could you post here some pictures about them? I'm interested in them if they are for the 2dr coupe.
How much would be the shipping to Hungary?
Thanks!
07-28-2006, 02:23 PM
ali i have to see if i have an extra set
i am parting a car soon and i think it has power mirrors
i would have to weigh them before i could give you a price qoute
Sutter what year is your corolla?
84 85?
like this?
[Image: AEU86 AE86 - Some parts that i sell]
Max
[email protected]
07-28-2006, 02:55 PM
No Max, mine is a '87 USDM Coupe (Levin actually but only after a conversion).
My tail lamps are the Type III, both is fine. It's only important that the shape is different like the one you linked.
Thanks!
07-28-2006, 10:50 PM
I am interesting in the ZENKI LEVIN POP UP GRILL. Can you send me a picture ?
Thanks ! ^^
07-31-2006, 03:06 PM
Max how much is shipping for 2 pairs of mirrors in Greece?
And with which way can i pay you? ( i dont have paypall )
Thanks, Nick
  Sell AE86 Wheels JonnyAE86 1 6,133 05-22-2007 08:54 PM
Last Post: JonnyAE86
  Sell - Brand New AE86 Rare JonnyAE86 23 28,648 05-22-2007 12:25 PM
Last Post: Mux213
  Sell - AE85 Engine 3A JonnyAE86 1 4,118 04-26-2007 05:04 AM
  Sell - Trueno Interior JonnyAE86 1 4,115 04-26-2007 05:03 AM
  Some aftermarket parts FS ke86 48 48,986 03-21-2007 03:17 AM
Last Post: ke86
