Some wiring help needed
05-15-2019, 11:22 PM
Anybody who knows where these wires are for?
05-16-2019, 10:04 AM
The wiring manual has a nice overview picture that shows what parts of the loom exit where in the engine bay, I suggest you compare with that picture.
Looking at the general location and the wire color my money is on the backup-light switch.. FABRICA MI DIEM, PVNC! |
05-16-2019, 12:12 PM
will do. this is by the way the place where it's coming from
05-16-2019, 02:46 PM
R/B wire color + location seem to point to backup-light switch too.. they look to lead toward the firewall but I expect its somewhere on the gearbox.
05-16-2019, 11:36 PM
(This post was last modified: 05-16-2019 11:39 PM by jondee86.)
Wires come out of the engine wiring loom where it runs across the
firewall and drop down to under the car. There are two pins high on the filler side of the gearbox, and those wires should have female bullet connectors on the end. The wires are only in the engine loom for 15cm and then run up into the big square(ish) plug that connects to the ignition switch etc. That is for RHD, if you are LHD the layout might be different. Turn the ignition ON and touch those two wire together... your backup/reverse lights should turn ON. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
05-18-2019, 01:50 PM
(05-16-2019 11:36 PM)jondee86 Wrote: Wires come out of the engine wiring loom where it runs across the Thanks a lot guys! 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
Tail light wiring... | Mylesmck | 4 | 1,042 |
02-02-2024 12:36 PM Last Post: Mylesmck |
Lambda sensor wiring | sam3007 | 10 | 4,556 |
Help needed | totta Crolla | 3 | 3,916 |
05-15-2020 10:07 AM Last Post: totta Crolla |
4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 7,018 |
06-20-2019 11:38 AM Last Post: Lykowsky |
Help needed: is it 1 way or 1.5way LSD | Dino86 | 2 | 3,651 |
05-17-2019 09:08 AM Last Post: Ivan141 |
