Spark from ignition coil
12-10-2004, 09:24 PM
Im based in the UK and I recently imported a Japanese AE86. Its a full drift spec car. I will post pics soon.
![]() The car has been misfiring and I noticed a spark coming from the ignition coil. The missfire seems to happen when the spark comes out of the ignition coil. I replaced the lead going from ignition coil to distributor cap but the problem still occurs. The spark goes between the two bolts on the ignition coil. Should there be some kind of cap on these bolts ? Can somebody post a pic of an ignition coil? Can anybody else suggest anything alse to get my AE86 running smooth ? |
12-10-2004, 10:25 PM
330uk,
welcome dude, I'm afraid I'm not to knowladgeable but I'm sure someone here can help you out ![]() ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
01-05-2005, 02:19 PM
Just buy new ignition coil.
Ignition switch plug and wires | Blaze0010 | 3 | 608 |
Smallport coil | totta Crolla | 2 | 1,929 |
08-12-2022 11:03 AM Last Post: totta Crolla |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 14,143 |
How to test coil with igniter | DJexor | 2 | 8,289 |
03-22-2018 10:01 AM Last Post: Project D |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 16,113 |
