Spark plug wires
02-09-2005, 03:16 PM
Spark plug wires
I was talking today with guy from Magnecor about the spark plug wires, so it might be good to share some info with you.
http://www.magnecor.co.uk/pdfs/p-t.pdf AE86 4A-GE blue top (83-87) part number 45103 8,5mm cable set £57 + VAT + PP AE92(A) 4A-GE red top (89-91) part number 45467 8,5mm £69 + VAT +PP Person on the phone told me that they are selling a lot of these late times . He left a good impresion on me by knowing a lot about 4A-GE variations and subversions. IHMO Magnecor are THE cables to buy if you have the money. If you are bit short on money like me, the you should consider this: http://www.pdm-racing.com/products/toyota_corner.html NGK Spark Plug Wire Set for the 1983-1987 AE86 - $44.25 or http://forums.club4ag.com/topic.asp?TOPIC_ID=95065 10mm Plug Wires & Free NGK Irridiums $75.00 + shipping!!! EDIT: i've read somewhere on the net that 4A-GE spark plug wires need correct impendancy, so be careful when replacing original cables. I'll try to dig out that information on the net. Drifting - best fun you can have in your car with your pants on! |
02-09-2005, 03:46 PM
Spark plug wires
Personally I like the Paradise racing stuff a lot, also nicely priced including iridium plugs.
02-09-2005, 04:05 PM
Spark plug wires
Unless you are boosting, OEM is best. The rest is just throwing away perfectly good money at a set of sparkly cabels. It would be better spent somewhere else.
Correction, you're probably okay with OEM wires when boosting also. Problems start at around 1 bar boost, but even then, most of the times a stronger coil solves the problem, not the wires. A wheel to steer the front of the car A pedal to steer the rear |
02-09-2005, 04:53 PM
Spark plug wires
NoHachi Wrote:Unless you are boosting, OEM is best. Might be, but how good are 20 years old cables and what is the price of Toyota OEM cables? Drifting - best fun you can have in your car with your pants on! |
02-09-2005, 05:24 PM
Spark plug wires
You have to be creative regarding OEM. NGK cables without the toyota logo work just as good as the ones with logo. 20 year old wires can work just fine, but it never hurts to replace them just in case. Signs of sparkwires failing are hesitation at certain rpms, nervous idle quality (could be a dozen things though) etc. If you don't suffer from these symptoms then you're probably better of investing is some other part of your hachi.
I say this coming from the MX5, which has a tendancy to go through wires every two years. You really do notice a difference when they are ready to be replaced: in the mx its the 3000rpm hesitation. No power what so ever to be gained by running expensive wires or using larger coils (MSD etc). A wheel to steer the front of the car A pedal to steer the rear |
02-09-2005, 05:49 PM
Spark plug wires
NoHachi Wrote:No power what so ever to be gained by running expensive wires or using larger coils (MSD etc). Yeah i know that. But poweah is lost if you are running the bad ones. Drifting - best fun you can have in your car with your pants on! |
02-10-2005, 12:59 AM
Spark plug wires
I need a set of spark plug cables. My local dealer found 2 prices, 55 and 180 E. The 2 prices where for different types of engines(in years).
Can I use them both and wath makes the diff in price?I thought 180E is to much for me. What are OEM cables, is this original toyota. I just need a reliable set (no power gain). |
02-10-2005, 01:10 AM
Spark plug wires
@Zax: Looking for this maybe? :wink:
AE86 FANATIC!!! |
02-10-2005, 11:32 AM
Spark plug wires
I bought the original toyota spark plug cables this summer, price about 80 euros (5 cables) at toyota dealer.
02-10-2005, 11:36 AM
Spark plug wires
I'm also interested in new spark plug wires. If you guys decide to organize a group buy, count on me.
Ignition switch plug and wires | Blaze0010 | 3 | 430 |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,180 |
Plug ID | kazi | 6 | 6,471 |
02-17-2019 10:07 PM Last Post: kazi |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 15,542 |
16v distributor hole plug | harkes | 8 | 9,612 |
