Start wont turn over after installing radio
09-16-2014, 11:31 PM
Hey Guys,
When i first bought the car i installed a kenwood radio. When i played some music the starter won't turn over. buy pushing the car and starting there suddenly fixed it. since then the car always ran if i did not play music (did not have any speakers in the car) Now today i installed my pioneer radio with 2 speaker, (40 watt in the original panels) After listening to 2 songs i left the car (radio turned off) after that the starter won't go around again -_-" I just connected the wires to some man made wires under the dash, but they contained old radio stuff where i just added it to. Gonna fix it soon but what about my starter ????? Build your dreams. Ford Puma 1.7 Zetec-s Daily Toyota AE86 Levin Coupe "Jinxy"- Dreamcar Mitsubishi sapporo - bosuzoku project |
09-17-2014, 12:24 AM
Bad battery/alternator ?
09-17-2014, 10:28 AM
Sounds indeed like a bad battery (or alternator not charging a lot) or a bad ground connection.
The 4age starter is prone to not start with suboptimal batteries. Use a multimeter to check the voltage on your battery (should be 12.2 volts) and start the engine (jump start) and check the voltage again and it should be above 13 volts for a normal charge (around 2000rpm). If the alternator is to blame the voltage should be below 13 volts when the engine runs, however if this is normal and the battery also has a good voltage you may should check the main ground connection. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
09-18-2014, 05:27 PM
Hello guys,
So this is what i did yesterday *Rolls out the AE86 from the garage* Okay *instert key en turns - klik* DAMN First thing then : check the battery = 13.40 Volts Mmmmh should be enough. *Grabs hammer* Can't stop, hammer time! 1 gentle tap with the hammer on the starter. *turns key* - *huf huf huf huf huf huf BROAM BROAM* Fixed. Then i installed my subwoofer and amp. started the car few times. no problem. Banpei what are the best batteries for a AE86 ? will be taking a hammer along now when i'm driving Build your dreams. Ford Puma 1.7 Zetec-s Daily Toyota AE86 Levin Coupe "Jinxy"- Dreamcar Mitsubishi sapporo - bosuzoku project |
09-22-2014, 04:36 PM
Bad solenoid.
09-22-2014, 11:06 PM
Start wont turn over after installing radio | |||
09-22-2014, 11:13 PM
Refreshed 20v blacktop first start.. | Mylesmck | 6 | 682 |
PWR light issue and no brake fluid after winter storage | magpie | 10 | 2,620 |
Warm start problem | DJexor | 5 | 2,228 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,351 |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,729 |
