Steering Rack bushings
03-10-2010, 12:26 AM
hello ,
Do you have problem with your steering rack bushings ?
Got them changed 5 times now . Each time passing Mot control , i'm rejected for that reason .
Does anyone knows if stiffer bushings exist?
I saw this on Techno Toy Tuning , but don't know if it's what I need (i have manual rack) http://www.technotoytuning.com/productdetail.php?p=112
Anything else to reolace stock bushings ?
Regards
Filh
Filh
Save the RWD cars
03-10-2010, 08:30 AM
http://cgi.ebay.com/AJPS-Corolla-ae86-ke...335ae4f526
take a look at the above link Filh :wink:
03-10-2010, 08:38 AM
filh! THE bushing you linked is an adapter bushing for using manual rack in an originally power steered car (the rack housings are different in size -> different mounting on the front member, so they are not interchargable by default)
prothane has the bushings you need. red urethane just like any other bushings for the 86 by prothane.
ajps also good.
[Image: AEU86 AE86 - Steering Rack bushings]
03-12-2010, 10:45 PM
Many thanks to both of you .
On Ebay, AJPS bushing is no longer listed .
Found Prothane here
http://cgi.ebay.com/ebaymotors/ws/eBayIS...0241174887
Prothane ref is 18-702
Also same as Toyota MR2 MkI
Thanks and regards
Filh
Save the RWD cars
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 6,739 07-31-2019 11:28 AM
  Quaife quick rack totta Crolla 19 20,825 03-03-2018 03:32 PM
Last Post: Deuce Cam
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 43,056 10-02-2014 06:07 PM
  Poly vs OEM bushings Jezza_hr 5 7,586 05-14-2014 11:28 PM
Last Post: Jezza_hr
  Play in power steering rack help phill 92 5 6,381 10-25-2012 12:01 PM
Last Post: allencr
