Steering U-Joint
02-02-2012, 01:33 PM
Steering U-Joint
Hi, my steering U-Joint is worn on my treuno.
Its got a manual rack on it. I ordered a U-Joint from a MR2 MK1 but it doesn't fit as both ends have a 1cm where as the 86 U-Joint is 1cm the steering wheel end, and 2cm the steering rack end. Can someone tell me where I can get another one from? Which car can I get one from? Or a part number? Or does anyone have a decent one to sell me? Really need one ASAP. Any help is greatly appreciated. Thanks, |
02-02-2012, 05:29 PM
Steering U-Joint | |||
02-03-2012, 10:50 PM
Steering U-Joint
Thanks for the PN but where can I get this part from?
02-03-2012, 11:44 PM
Steering U-Joint
Your Toyota dealer :wink:
02-05-2012, 05:40 PM
Steering U-Joint
I have now found that its not a manual steering rack. Its a power steering rack with the power steering taken off.
Is this still the same part number? Its 1cm at one end and 2cm at the other. Please help. |
02-07-2012, 07:05 PM
Steering U-Joint
If it's 45209‑32010 you want, then your spoilt for choice, as it was fitted to many Toyota models.
Here's a list of possibles... http://shkgiec.en.made-in-china.com/offe...2010-.html The MR2 AW11 u/j is p/n 45209-17010 and is supposed to fit when swapping to a manual rack. [I think it's the same as above, though]. One p/n for AE86 u/j with power steering is 45209-12040. That could be difficult to find. You might also want to have a look at http://www.modified.com/projectcars/0712...ewall.html to see the parts side by side. http://www.AE86imports.0catch.com |
Why Manual Steering Rack ?? Power Steering Removal | juantonwan | 26 | 45,052 |
Propeller shaft universal joint | kawo | 1 | 4,540 |
05-19-2014 11:05 AM Last Post: Uzelac |
Steering U-joint welded - options? Rear axle ? | ggrahl | 9 | 9,269 |
12-26-2011 06:41 AM Last Post: ggrahl |
U-joint on drive shaft - Beams 6s box | KD2229 | 3 | 5,287 |
08-18-2011 03:59 AM Last Post: KD2229 |
Ball joint removal with arm attached?? | juantonwan | 3 | 6,559 |
05-06-2010 04:44 AM Last Post: juantonwan |
