Steering joints
04-06-2009, 10:25 PM
Steering joints
Does anyone know if the inner ball joints ( the ones attached directly to the rack ends) are sided left / right ?
On full droop with the car jacked up the driver side track rod end is under tension, being pushed down. The inner joint appears not to have enough articulation and is binding before the strut is fully extended Confused
04-07-2009, 08:37 AM
Steering joints
the rod themself are the same only the rubber boot is sided
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 45,201 10-02-2014 06:07 PM
