Stock Bigport Engine + ITB?s?!
06-12-2013, 04:07 PM
Post: #31
That's the plan!
gon has everything explained regarding the MS! Smile
06-13-2013, 11:28 PM
Post: #32
Andrax Wrote:the opportunity to keep upgrade the engine with no limits.
Ummmmm..... No....... OEM ITBs only have so much they are adequate for...
then you move on to something like TRD throttles...
[Image: AEU86 AE86 - Stock Bigport Engine + ITB?s?!]
and then you hit another wall... so you move away from ITBs and go for slide throttles....
And once you hit the wall with slide throttles... you move on to barrel throttles
So... DON'T believe everything people tell you.... do your research.
As Bean Bandit point out... I making somewhere between 165 - 170hp on a single OEM throttle body
Dan -
06-13-2013, 11:51 PM
Post: #33
I'm cool with 150HP on my AE86 Smile That's pretty much my goal...
Evil
06-14-2013, 09:52 AM
Post: #34
Thanks for your post oldeskewltoy. Really nice draws on CAD!
I was referring to the engine management. Let's say the use of the itbs are more an excuse to go for free tune engine management.
I know after that we need to go for expensive engine hardware, but I don't plan to build any highly tuned 4age. Anyway its incredible how you achieved 165-170hp with stock TB, but I know its possible. I would be happy to reach the same mark!
Maybe I'll need some advice to port the head (I have one already ported for someone else) so I need to know if its fine or I need to start from the beginning. And the other small tricks that makes the difference to push some more hp from his engine!
Thanks
06-14-2013, 10:34 AM
Post: #35
just for your info , I put some ae101 itbs on my bigport with catcams 260° / 252° 9.00 / 8.50mm (these are for stock head) with the martelius header and exhaust running on haltech ecu. I got something like 152hp. spend a lot of money and time. I wanted the response and sound of itbs but I guess would not do it again Wink well car is somehow street legal in my country, only reason I did not go for other cams, higher compression pistons and keeping the good ol tvis.
http://nuudelbahn.wordpress.com/
http://www.superlapbattle.lu
https://www.facebook.com/SLBRaceleague
06-15-2013, 07:19 AM
Post: #36
In the 4AGE community there seems to be two kinds of people... those
who believe bigger is better no matter what, and those who believe size
doesn't matter... it's how you use what you've got :wink:
If you want bragging rights at the dyno, you have two choices... pour a
big heap of cash into a N/A engine, or slap on a big turbo. Either
way you are liable to end up with a peaky engine that is really only at
home on a race track... not that there is anything wrong with that Smile
The other kind of people are not much concerned with how much power
they make. They want to improve one or more aspects of their car to
make it a better than it was, and more fun to drive. They want it handle
on the streets of their city and look good while doing it. And when the
opportunity presents, carve up backroads on a fine afternoon. You can do
this with an honest 150hp at the wheels.
But the one thing everyone has in common when messing around with
underpowered and beaten up 25 year old cars, is the desire to do
something for yourself. It does not have to make sense. There is intense
satisfaction in modifying cars to test your own ideas. And this is how we
learn... make mistakes... fix them, and one day drive that car you built
out of the garage...
Hurray! Hurray! Hurray!
It would be a boring world if everyone did the same thing !!
Cheers... jondee86
  Digital speedometer on stock dashboard FanIsHere 0 1,503 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 2,930 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,723 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,762 03-24-2019 04:10 PM
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,611 04-20-2018 09:14 AM
