Stock ride height
09-28-2011, 07:47 PM
Stock ride height
So if anybody´s out there rollin on stock suspension setup - i need help. I´m planning to lower my hachi during the winter break but i don´t have any clue about how much lower my hachi is right now.
So i want to know the lenght between the wheel arches (front and rear) and the center of the hub. Anybody can help? ![]() Uploaded with ImageShack.us AE86 Full Hybrid - Burns rubber and gasoline |
09-28-2011, 08:25 PM
Stock ride height
my car is actually at stock height but with a modified fender. I can meassure the distance from the floor to the headlight if this might help you
09-29-2011, 03:46 PM
Stock ride height
Yeah this would help me too. Let´s say from the under edge of the headlight to the ground. Even from the underside of the mirror to the ground should work...
09-29-2011, 04:19 PM
Stock ride height
From
http://ae86gt.forumactif.com stephane.h Wrote:Salut a tous,comme dis dans le titre,j aimerais rassembler des infos concernant les hauteur de caisse des 86 ![]() |
09-29-2011, 04:28 PM
Stock ride height
Hm, i should take a look in the manual before asking
![]() AE86 Full Hybrid - Burns rubber and gasoline |
09-29-2011, 07:15 PM
Stock ride height
yes your 14" wheels are ~11.5mm smaller than the 13" so add 11.5mm to what you measure for comparison with the manual.
AE86 ex-daily |
09-29-2011, 07:41 PM
Stock ride height
So after adding its about 18cm - so it´s dropped about 5cm / 2inch. But unfortunately it looks like there aren´t shorter springs available...
09-29-2011, 08:16 PM
Stock ride height
you sure you haven't miss measured - I have the APEX springs (~30mm lower) and my rideheight looks similar to yours in the top pic.
AE86 ex-daily |
09-29-2011, 08:22 PM
Stock ride height
Now i´m doubting myself
10-03-2011, 05:40 PM
Stock ride height
Measured again, as i said... 18cm. I cant tell the brand of the springs and shocks cause it´s all burried under a thick layer of underbody protection ( is it called like this
![]() Springs use to settle a bit after a certain time... maybe your´s did. Are the 30mm measured or is it the value promised by APEX? AE86 Full Hybrid - Burns rubber and gasoline |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,615 |
82mm Stock compression Pistons | apardal | 4 | 3,118 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 14,142 |
Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 5,921 |
03-24-2019 04:10 PM Last Post: oldeskewltoy |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 6,105 |
02-20-2016 11:48 AM Last Post: Bean |
