Stock timing map?
05-27-2009, 07:44 AM
Stock timing map?
cylinder filling is the load right, the values in the table are referring to a certain degree for BTDC - if you compare the table on page 12 with the table on page 16 you should be able to make a table in degrees.
if you read the text to page 12 it states the values are from 0 to 255 (min to max degrees)
probably the easiest way is to try and calculate one point of both tables to get a conversion factor from the 8bit code to degrees.
Hope that helps
  Digital speedometer on stock dashboard FanIsHere 0 1,388 11-09-2022 01:36 PM
Last Post: FanIsHere
  AFM to Map Conversion ps13michi 3 3,168 01-06-2022 10:34 AM
Last Post: ps13michi
  82mm Stock compression Pistons apardal 4 2,815 11-24-2021 04:26 PM
Last Post: apardal
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,010 02-10-2020 06:39 PM
Last Post: Power_uP
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,459 07-18-2019 03:52 PM
