Stock timing map?
05-27-2009, 07:44 AM
Stock timing map?
cylinder filling is the load right, the values in the table are referring to a certain degree for BTDC - if you compare the table on page 12 with the table on page 16 you should be able to make a table in degrees.
if you read the text to page 12 it states the values are from 0 to 255 (min to max degrees) probably the easiest way is to try and calculate one point of both tables to get a conversion factor from the 8bit code to degrees. Hope that helps AE86 ex-daily |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,239 |
AFM to Map Conversion | ps13michi | 3 | 2,917 |
82mm Stock compression Pistons | apardal | 4 | 2,622 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 10,512 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 12,983 |
