Strange moment curve
07-30-2013, 08:30 AM
I bought this set of cams specified as 280 IN and EX but have later found that they are probably not
![]() I have had great difficulty finding any specs on these cams. What I have is: 200a158000h 258 gr exhaust - road 200e196000w 296 gr inlet - rally/race |
07-30-2013, 09:55 AM
harkes Wrote:I bought this set of cams specified as 280 IN and EX but have later found that they are probably not Hi Niels I have a set of schrick cams you can lend if you want too. Specs for the camshafts: 200E1960-00: opening duration: 296° lift max.: 8,6mm peak timing: 105° lift at TDC:3,3mm and 200A1960-00 opening duration: 296° lift max.: 8,6mm peak timing: 105° lift at TDC:3,3mm Regards Lars ( They are located in Ikast) http://s141.photobucket.com/albums/r69/larszylauv/ |
07-30-2013, 11:21 AM
the pulses in the engine are not working because off you cams set up
and remember that the "old" gr A cams are for big port head with STD peleaum chamber and carst iron exhaust manifold. and maybe a bad porting off the head also I will sugest a set off new cams |
07-30-2013, 11:28 AM
and I forgot
the R1 is made for torque, not the best for this old RPM cams (inlet) |
07-31-2013, 07:31 AM
rene Wrote:and I forgot Hi Rene You seem to know a bit about this R1 exhaust. Which cams would you recommend then? Any suggestions for the length of the inlet funnels? |
07-31-2013, 10:26 AM
hi Lars
is it a racing engine ? or road retainers, springs, STD or followers ? funnels you mean air horn ? I find the best length on the rolling road where did you get the R1 from ? or the idea to use it ? |
08-02-2013, 10:29 AM
Strange moment curve | |||
08-06-2013, 06:11 AM
Engine finished on the dyno... Result somewhat different than expected. These cams was bought 2. hand as ~280 - dont think they are...
08-06-2013, 09:15 AM
That's making good torque high in the rpm range... I would be happy
![]() Cheers... jondee86 |
08-06-2013, 02:42 PM
I don't know what you have expected
but this are low lift cams with duration, then you get power in the high rpm range and not a masive torque |
Strange ignition problem | kpretro84 | 12 | 25,653 |
04-20-2013 02:34 AM Last Post: jondee86 |
strange sound from steering | Ryo | 10 | 12,970 |
04-21-2011 07:04 PM Last Post: allencr |
Strange timing issue ? | totta Crolla | 11 | 13,169 |
06-18-2010 01:48 PM Last Post: totta Crolla |
Halfshaft moving in & out - strange problem | max_ae86 | 6 | 6,758 |
05-22-2010 10:16 PM Last Post: max_ae86 |
Strange TRD pistons 4a-ge | Mikzu IV | 12 | 29,565 |
03-19-2010 11:08 PM Last Post: Jimmi The Kid |
