Surreptitious.....
02-05-2017, 02:51 AM
Post: #221
Surreptitious.....
I try to be careful when it comes to accessorizing Surreptitious... don't want her looking trashy... So these became available....
and I jumped on them... fit isn't bad... They are just propped in there for now, I'll need to come up with a method to mount them securely as the original mounts were not included Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-05-2017, 10:11 AM
Post: #222
Surreptitious.....
looks good!
02-06-2017, 02:59 PM
Post: #223
Surreptitious.....
Looks great!
But I always had a thing for 70s louvre window style 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
02-06-2017, 06:23 PM
Post: #224
Surreptitious.....
Looking very tasteful Dan. Though I'm astonished not seeing any snow in these pictures...
Sent from my SM-T800 using Tapatalk AE86 ex-daily |
02-06-2017, 06:56 PM
Post: #225
Surreptitious.....
(02-06-2017 06:23 PM)Bean Wrote: Though I'm astonished not seeing any snow in these pictures... no snow???? yeah... I got your snow....... Had so much snow I had to put the studded Hakkapeliitta 4's on my All-Trac - aka Grunt Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-06-2017, 07:24 PM
(This post was last modified: 02-06-2017 07:27 PM by Bean.)
Post: #226
Surreptitious.....
wow, that's more like it. Martina is very jealous
is that about 1.5 feet overnight? Sent from my SM-T800 using Tapatalk AE86 ex-daily |
02-07-2017, 06:47 PM
Post: #227
Surreptitious.....
(02-06-2017 07:24 PM)Bean Wrote: wow, that's more like it. Martina is very jealous She can have it!!!!! This has been the most snow in Portland since we have been here. The local ski resort (Timberline on Mt Hood) has a base of 130"(330+cm)! The photos above are from the storm in mid January (11&12) Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-03-2017, 11:44 PM
Post: #228
Surreptitious.....
Pretty much since she has been roadworthy... she has had an annoying vibration at the front of the car when @ idle. It was slightly embarrassing as it idle, and made noise. For the longest time I had thought it was the air dam vibrating against the custom bumper. So I decided today I had had enough and I looked at what I could do. First, I tried to adjust the bumper... to no avail, the vibration continued. Then I climbed under the front while it was idling... and I saw the problem...... The air dam was indeed vibrating against something, but it wasn't the bumper. The airdam is shaped in such a way that the back side that fits to the lower valance, was vibrating.
I've fitted some foam weatherstripping between the air dam and the valance panel and the vibration is GONE! Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-06-2017, 03:40 PM
Post: #229
Surreptitious.....
Sometimes it is just a simple small thing. I had such an issue with my Carina where something on the dashboard would rattle when stationary. Even after removing and reattaching every panel it remained. It ended up to be a loose louvre inside the air vent...
03-07-2017, 10:35 PM
Post: #230
Surreptitious.....
(03-06-2017 03:40 PM)banpei Wrote: Sometimes it is just a simple small thing. I had such an issue with my Carina where something on the dashboard would rattle when stationary. Even after removing and reattaching every panel it remained. It ended up to be a loose louvre inside the air vent... part of my fear of installing the interior is more things to vibrate.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
