Surreptitious.....
03-28-2017, 08:45 PM
Post: #231
Surreptitious.....
repairs????
Was out running a few heads out to the machine shop and all of a sudden the blinkers slow to a crawl.... found the directional relay, and replaced it.... Oh... I also acquired(purchased) a new set of wheels.... 15x6.5 +19 for the fronts, and 15x7 + 13 for the rears.... should be here in about 2 weeks...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-29-2017, 06:26 PM
Post: #232
Surreptitious.....
Looking forward to see pictures of the wheels fitted.
AE86 ex-daily |
05-02-2017, 05:55 PM
Post: #233
Surreptitious.....
The wheels arrived.... and while not bad.... they are no longer 3 piece wheels, they were welded, so they are now 2 piece wheels.
I had intended to keep the 7" - +13 pair as the fronts, and convert the 6.5" - +19 wheels into 7.5" - +6... but that would now take serious surgery to accomplish. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-02-2017, 07:58 PM
Post: #234
Surreptitious.....
Guess it's a questions if you can get a whole barrel in the correct offset
AE86 ex-daily |
05-03-2017, 05:53 PM
Post: #235
Surreptitious.....
(05-02-2017 07:58 PM)Bean Wrote: Guess it's a questions if you can get a whole barrel in the correct offset maybe.... I may just clean and run them.... the Drag 902 5 spoke wheels I currently use are 15 x6.5 +22, so even the "smaller" mesh wheel still has a bit more offset........ Who knows maybe I'll go full in "Muscle car" and run staggered tires along with the staggered wheels. Last time I did that was 1979... in my 1969 GTO... I ran F 70 14s(215/70/14) in the front, and H 60, 14s(245/60/14) in the back - Firestone Super Sports... something like these..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-03-2017, 09:34 PM
Post: #236
Surreptitious.....
Wow! That would look mad!
09-13-2017, 11:29 PM
Post: #237
Surreptitious.....
(03-28-2017 08:45 PM)oldeskewltoy Wrote: repairs???? More repairs.......... well it has been over 7 years and close to 25k miles.......... Lost one cylinder all of a sudden on Tuesday... she sounded like a Subaru I pulled plug wires and #1 cylinder was not firing I swapped #1 and #4 @ the coils, and now #4 was not firing. Borrowed a friends coil pack, and she fired up on all 4. Decided to purchase 2 coils so both will be new/fresh. More to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-14-2017, 07:42 PM
Post: #238
Surreptitious.....
glad it was an easy fix and hope other potential repairs will be too
AE86 ex-daily |
03-01-2018, 06:30 PM
Post: #239
Surreptitious.....
Feb of an even year.......
Its emissions testing time again. I brought her through, and while not a "gross polluter", she did fail on hydro carbons 400ppm, the level is 220. The cat is now 3 inspections old, and so I replaced the cat, and went back through......... As you can see a nice new cat and she is very clean @ 1ppm for HC, and .011% CO Shes' good for another 2 years. Not bad as she is heading into her 9th year as her new self...... as always......... more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-01-2018, 11:38 PM
Post: #240
Surreptitious.....
Congratulations, so the CAT lasted 6 years?
Sent from my MHA-L29 using Tapatalk AE86 ex-daily |
