Poll: which one to go for
KW Comp2 custom made
Stance ProComp3
BC ER-Type
BC BR-Type
DIY coils based on HTS
other - please mention in post
[Show Results]
Suspension Opinions - Please vote!
05-21-2014, 11:31 AM (This post was last modified: 05-21-2014 11:50 AM by Bean.)
As some of you know I've been pondering about what suspension to get for when I finished my engine build which should be sometime this year.
Now I narrowed it down and also did a lot of research but the lack of actually being able to drive cars with suspension setups aim aiming for myself makes a decision extremely difficult for me.
So here goes - after 8 years of daily service my car is now a weekend warrior. I drive on the street as well as on track. I need/want the suspension to work properly, i.e. not jump around the Nurburgring just because it's not the smoothest track in existence. A bit of comfort wouldn't go amiss either as trips to the track sometimes take 6h one way.
Please state your opinion and elaborate - personal experience preferred.
I'm aiming for spring-rates in the region of 6/4.5 as I've driven Greddy Type-S and it's miserable on average roads.
Some details to the choices:
KW Comp2: custom built (2way adjustable) - need to send in camber-plates and spindles - ~2200euro (high quality and price)
Stance ProComp3: custom built (3way adjustable) - new spindles and camber-plates ~2000euro (quality? and highish price)
BC Racing ER Type (2way adjustable) - new spindles and camber-plates ~1800euro (quality? and highish price)
BC Racing BR Type (combined adjustment) - new spindles and camber-plates ~ 950euros (quality? and cheap)
DIY coils on HTS base ~650euros (used parts so cheap)
Although I can afford the KW Comp2 I'm still pondering if it's really worth it... after all it's not a small amount of cash.
05-21-2014, 12:47 PM
I would go DIY with TRD or HTS.
I am running 6/5.1 kg/mm springs with TRD adjustable dampers and it is way better than K-sport/D2/yellow Koni on bad roads. I might go softer if I had to start over - like 5/4...
[Image: AEU86 AE86 - Suspension Opinions - Please vote!]
05-21-2014, 12:52 PM
(05-21-2014 12:47 PM)Jan Pedersen Wrote:  I would go DIY with TRD or HTS.
How did your setup do on the ring? Do you still run the stock sway bars?
Sent from my Nexus 4 using Tapatalk
05-21-2014, 01:39 PM (This post was last modified: 05-21-2014 01:39 PM by NoHachi.)
What was your original setup like? HTS longstroke+springs right? springrates? ARBs?
05-21-2014, 01:41 PM
(05-21-2014 01:39 PM)NoHachi Wrote:  What was your original setup like? HTS longstroke+springs right? springrates? ARBs?
Yes, HTS long stroke and APEX spring with unknown spring rate (30-35mm lower and I guess around 2-2.5kg springs).
05-21-2014, 02:25 PM
Yes, but what was it like? What did you like and not like about it. What problems where there (if any).
05-21-2014, 02:28 PM
It was too soft and I wasn't able to adjust the dampers to the springs. Either low or high speed was always of.
05-21-2014, 02:34 PM (This post was last modified: 05-21-2014 02:35 PM by d3nso.)
Got the BC BR Coilovers they are not bad no problems with it so far but will change them for a Bilstein Coilover set sometime in future (if i got too much money laying arround Tongue)
So voted for
[x] other
but would vote for the BC aswell.
Daily Beater: Civic EG5
Work in progress Car: AE86
05-21-2014, 03:56 PM
isnt bc 8/6,that is not an option for a semi street car.
I would go 5.5(6)/4.5 or so max.
05-21-2014, 04:00 PM
(05-21-2014 03:56 PM)ditn Wrote:  isnt bc 8/6,that is not an option for a semi street car.
BC now offer 6/4.5 too.
@NoHachi: forgot to mention stock ARBs. The car still has slight under steer tendencies with snap oversteer when pushed into corner too fast.
  Metal removal at rear, opinions 4000GT 43 43,679 01-03-2013 03:28 AM
Last Post: 4000GT
  Full coilover set G4 - opinions? El_Camino 5 6,428 04-02-2008 04:43 AM
Last Post: F0Bman
  Opinions on Tein coilovers for AE86..... peter møller 5 8,251 05-04-2007 10:17 AM
Last Post: peter møller
