Suspension modification
03-17-2005, 01:27 PM
It would be nice to have a sticky topic with people's feedback on what improvements will make the AE86 handle properly. So far information is spread everywhere around this forum making it hard to trace.
Obviously I'm not talking about details such as spring rates or rebound settings. These should be chosen by the driver depending on skill, car use, etc. I am more interested in certain issues that I have still not clarified in my mind like
Are adjustable 4-link rods necessary when lowering the car? Why? What will the difference in car handling/feel be with and without the upgrade? I remember reading something about the rods sitting at the "wrong" angle after lowering the car, but how does that affect handling?
How will difference in ride height between front and rear affect weight distribution? I'm guessing but wouldn't a lower front end mean more weight on the front tyres = more grip =less grip for the rear = oversteer?
I realise these may require comlete writeups from the more techniocally knowledgeable of you, but still they would be nice to have
Smile
03-17-2005, 01:40 PM
Dorito,
Well we need some way to manage that, especially when subjects get asked in parts its hard to get a sticky going.
I'll make this thread a sticky if people promise to post good information about suspention here!Smile
03-17-2005, 01:53 PM
great thoughts Dorito! Thumbs up!
We need these info gathered in one topic !!!
Please help us not so well technically aspirated guys... Respect!
03-17-2005, 03:39 PM
Please, add all these to "Articles" - I think this is the "Articles" section about.
04-06-2005, 10:26 PM
[Ivanhoe translation service:]
Tip for the front shocks: for some firmer dampening you can remove the original shock inserts (if you still have those) and refill them with 5w30 engine oil and reassemble..they should be a lot stiffer after that.
tip voor de voorshockers. ja in het nederlandsTongue
voor wat meer demping (zoals koni's) demonteer de originele dempers en laat de olie eruit lopen.
hervul ze met een 5w30 motorolie, en zet ze weer in elkaar.
Je hebt nu flink stuggere dempers, ik rijd zo al jaren rond .
ae86
04-06-2005, 10:48 PM
Nice try ae86 but only if we could understand that language... Dumb question
04-10-2005, 09:51 PM
...as for mod´s....
my car has:
sparco springs (-30mm) discontinued Dumb question
koni sport shocks (70% hardness adjusted)
prothane polyurethane bushings
front and rear strut braces...
t3 adjustable camber plates
t3 roll center adjuster´s (rca)
...i thing these are the basic mod´s that improve the car handling dramatically Cool ....of course, associated do wider wheels and good grip tires....
in my case, konig rewind´s 14x7 -9 ....
04-10-2005, 10:55 PM
my front setup...
04-10-2005, 11:03 PM
my rear set up...
KONI yellows set to 85% of max, twin swaybars
04-11-2005, 01:11 AM
Hey guys when the car is lowered is it necessary that we install both the items i show in the picture? If yes or no please explain and name these items please... Respect!
  OEM LSD modification malejyetti 40 53,453 06-23-2016 12:34 PM
Last Post: pack
  Fuel Tank Modification apardal 1 5,465 08-11-2014 06:59 PM
  All I should know about suspension before any modification damusto 20 21,306 05-24-2013 09:28 PM
Last Post: damusto
  Possible body change/modification, need help. Rascal21 2 5,208 11-08-2008 11:57 AM
  TRD - Sports parts & Modification manual Onyx 32 27,043 04-01-2008 08:27 PM
Last Post: speed-inc
