Suspension modification
10-05-2005, 03:10 PM
Post: #31
Jezza_hr Wrote:What Shocks are best suited to a 35mm drop in height?
IMHO front Koni sports for AE92 + 5mm spacer in the case.
10-05-2005, 03:18 PM
Post: #32
Is there anything specific to use for the spacer? Also have you got the part numbers for the shocks? What do you run on the rears?
10-05-2005, 03:29 PM
Post: #33
Fiat Argenta front ones - just re-fit bushings in the low end of the shock. They are 30mm shorter than original rears of AE86.
I made steel spacer 10mm (because I try to lower the car 30mm and I shorten the cases 30mm) and I shim using 1mm steel washers :-)
I use KYB gas AE92 fronts - non-adjustable.
http://rudy96.com/pricelist.htm Prices in Bulgaria (2 BGN=1 EU)
Use P/Ns from here:
http://www.koni.com/_cars/_products/cata...4_2005.pdf
10-05-2005, 03:37 PM
Post: #34
Thanks very much. Thumbs up!
10-14-2005, 11:49 AM
Post: #35
got a set of
Yellow koni adjustables for the AE86 all around and a set of
TRD race springe group N 8kg/mm front 7kg/mm rear very nice!
11-30-2005, 02:06 AM
Post: #36
It seems Yellow Konis are the choice to make for dampers, but I'm getting lost on what springs to get...
What alternatives are there to TRD?
How stiff are the standard springs as compared to the TRD ones?
In Denmark we have the added issue of having to get something that is TÜV approved or it won't pass MOT. This unfortunately rules out all the exotic stuff from japan, homemade coilovers etc. :-( (Of course, if it looks like it's supposed to be there there's a chance it'll pass anyway)
Peugeot 206 1.6 XT - 09/2003
Toyota Corolla GT Coupé - 09/1984
Yonzie - 09/1980
11-30-2005, 02:08 AM
Post: #37
By the way, at club4ag Paradise Racing has made a Xmass offer:
2 Front blue Tokikos+front coilover set+springs of choise= 255 dollars!!!!!!!!!!!!!!!!!!!!!!!! Looks pretty good to me :wink:
[Image: AEU86 AE86 - Suspension modification] http://www.jdmbits.com
11-30-2005, 08:28 AM
Post: #38
ehm, if you mean the blue Tokico HP's then that really isnt all that cheap.
You can buy a complete set of Tokico's on ebay for 180 dollars or something..and the coiloverset is 150 dollars. Divide the amount for the Tokico's by 2 and you'll get the picture. BTW, I have tokico blues on my car and wouldnt recommend them for serious performance.
Disregard my entire reply if they are tokico illumina's...
11-30-2005, 10:52 AM
Post: #39
Nope, they are blues, but shipping is free for all tha lucky US residents
11-30-2005, 01:03 PM
Post: #40
yonzie reagarding TÜV aprooval. Just make one yourself Smile its a common practise here. Yes im saying you should counterfit the certificat. Its easy =)
  OEM LSD modification malejyetti 40 53,453 06-23-2016 12:34 PM
Last Post: pack
  Fuel Tank Modification apardal 1 5,466 08-11-2014 06:59 PM
  All I should know about suspension before any modification damusto 20 21,306 05-24-2013 09:28 PM
Last Post: damusto
  Possible body change/modification, need help. Rascal21 2 5,208 11-08-2008 11:57 AM
  TRD - Sports parts & Modification manual Onyx 32 27,043 04-01-2008 08:27 PM
Last Post: speed-inc
User(s) browsing this thread: 14 Guest(s)
