Suspension swaps from other cars ?
01-15-2012, 03:25 PM
Hey everybody,
I have been looking for answers but can't seem to find them.
The front AE86 suspension - including strut spindle and front axle hub
What other car brands or car types have almost the same identical stuff that you can maybe swap out with the AE86...
Or perhaps make it even better?
Especially the spindle and the front axle hub I need to know of.
Thanks.
-DWG- Drift Wolf Gaming
01-15-2012, 03:35 PM
you can make the Nissan 200sx suspension work on the front... it needs some adjusting though as the nissan lower arms are ~50mm longer.
So either you make sure to accommodate the wider track and run quite a lot of camber and wider fenders or you stay with the AE86 lower arms and make the balljoint fit the nissan spindle. Best solution to get a bit of both is probably a custom lower arm to give more track but not too excessive.
Another benefit of the nissan spindle (s13) is you keep the same wheel PCD and can use their brakes which have a lot more aftermarket support etc..
01-15-2012, 03:46 PM
Wow! Thanks Bean!
01-15-2012, 04:00 PM
more info somewhere in here:
http://www.aeu86.org/viewtopic/ae86/t/54.../start=423
01-15-2012, 04:49 PM
Ford escort mk2 suspension swap
see my technical topic about suspension.
  Springs from other vehicles?? FanIsHere 16 15,200 05-17-2016 09:12 AM
Last Post: FanIsHere
  AE86 Body Panels - From Other Toyotas? yellowsnow4free 5 8,082 01-24-2013 04:19 AM
Last Post: yellowsnow4free
  track questions:max oil/water temp,egt and other ditn 7 8,309 07-06-2012 12:40 PM
Last Post: ditn
  Do UK/Euro cars have an illuminated fog light switch? Lauren 9 10,178 08-22-2011 08:53 PM
Last Post: Lauren
  4AGE 20v Buy new clutch kit or other options JAVResistance 2 5,184 05-13-2011 08:02 PM
Last Post: Jimmi The Kid
