Swedged or crimped hose ends?
02-05-2010, 02:31 PM
Hey guys!
I am designing a brake system for my 86 and I'm not sure which method of fitting hose ends is more reliable... Does anyone have an opinion on that?
(I'm talking of course about stainless steel braided hoses running from dual master cylinders through T connectors and in line master cylinder for e-brake)
SFD
02-06-2010, 03:28 AM
crimp the edges.
From working with high pressure hoses in the oil industry of Norway. I can safely say that will be the best solution.
But, use a proper machine to cramp the hoses. You will need a even pressure the entire 360 degrees around the hose.
[Image: AEU86 AE86 - Swedged or crimped hose ends?]
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
02-10-2010, 09:01 AM
Thanks!
Well, I'm quite sure buying a crimping machine just to make 14 crimps will be a bit more expensive that to have them made... I suppose companies selling custom made hoses use proper machinery to obtain reliable crimps.
Maybe that one:
http://www.hrpworld.com/index.cfm?tpc=AN...on=product
SFD
02-10-2010, 01:11 PM
why not buy hose and fittings separately ? and asseble yourself, nothing extraordinary.
I've bought everything here
http://www.isa-racing.com/index.php/cat/...ungen.html
and here is small instruction for assemble (TFE for breaks)
I've also one question - I'm too will have separate front and rear cylinders.
my question is about hose lenght.
Rear is ok, it will be 100% equal, but what's about front?
does it need to be equal lenght after T-joint? stock lines are not equal, but I suppose what it make a difference.
owau no ka "I"
02-10-2010, 02:01 PM
This method is the so called "swedging". The original question regarded comparing reliability of this method (which of course anybody can do at home) with crimping.
I will make a T-joint in the middle for the front circuit also. The actual difference is very small, it has to do with pressure loss difference in the left and right lines. If you could actually feel this difference during braking it would be a slight delay in the brake force build up on the longer hose side. I guess there are a number of other factors that would make a braking system unbalanced, but every little thing helps, even for psychological reasons!
SFD
02-10-2010, 03:03 PM
Now understand about swedging, thnx.
and for lenght I'm agree as well, Bernoulli's principles works everywhere, will make my system equal lenght.
owau no ka "I"
  fuel line hose from the pump Wikizz 4 6,282 10-16-2017 07:11 PM
Last Post: jdm86gtz
  cool lower radiator hose thanos 4 5,760 11-29-2016 01:06 PM
Last Post: thanos
  rod-ends Lajoosh 10 9,926 03-27-2012 10:24 PM
Last Post: fax0815
  DIY/How-to: E-brake adjustment for GT-S rear ends. assassin10000 3 16,717 12-12-2010 11:47 PM
Last Post: Hachi
  Longer Tie rod / steering ends meshin 2 6,260 11-10-2010 01:57 PM
Last Post: meshin
