Switching diffs for disc brakes?
07-03-2022, 04:26 PM
I bought a 85 gts a while ago and I’m now getting to fixing it up only to realize it has drum brakes and a factory open diff. Would switching diffs be worth it? I would keep the diff if i could switch the drum brakes for disc brakes but is that even possible without changing diffs? I have the 282 diff code on my firewall
07-03-2022, 07:46 PM
You can fit the SR5 drum brakes on the AE86 axle and that used to be a popular mod to ensure better lockup at the rear to initiate drifts. The reverse is possible as well as this video outlines:
Also can you elaborate a bit more on that diff code? 282 normally is tied to T282, which is the AE86 axle. I have seen S314, S302 and S292. All those are AE85, Australian SR and USDM SR5 axle codes.
[Image: AEU86 AE86 - Switching diffs for disc brakes?]
07-04-2022, 06:45 AM
(07-03-2022 07:46 PM)banpei Wrote:  You can fit the SR5 drum brakes on the AE86 axle and that used to be a popular mod to ensure better lockup at the rear to initiate drifts. The reverse is possible as well as this video outlines:
Yeah I forgot the T
07-04-2022, 08:53 PM
(07-04-2022 06:45 AM)trippin Wrote:
(07-03-2022 07:46 PM)banpei Wrote:  Also can you elaborate a bit more on that diff code? 282 normally is tied to T282, which is the AE86 axle. I have seen S314, S302 and S292. All those are AE85, Australian SR and USDM SR5 axle codes.
Yeah I forgot the T
So now it really puzzles me: it's a GT-S, but it has drum brakes. The GT-S only came with disc brakes on the T-series axle. It sounds like a previous owner modified your car to drums for drifts, but since it has an open diff this doesn't make sense to me... Confused
07-06-2022, 04:29 PM
Yeah I forgot the T
Well I’m from puerto rico and parts are difficult to source here, could it be that he just couldn’t find an lsd and said f#ck it? Thx for the help btw
07-06-2022, 07:59 PM
(07-06-2022 04:29 PM)trippin Wrote:  Well I’m from puerto rico and parts are difficult to source here, could it be that he just couldn’t find an lsd and said f#ck it? Thx for the help btw
True, that could also be the case. Many of our cars have been repaired with parts available and it's becoming harder and harder to find them.
Maybe a stupid question, but did you verify it still has an open diff?
07-08-2022, 03:35 AM
That is a very good question and i have not. Would i have to Open the diff or does it have any identifier on it?
  Rear brakes totta Crolla 0 908 02-03-2023 12:54 PM
Last Post: totta Crolla
  Best quality Diffs gh0st 1 1,353 07-03-2022 07:49 PM
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,757 12-21-2016 09:37 PM
Last Post: bozu
  Hydraulic handbrake with stock rear brakes Dino86 11 15,268 07-11-2014 08:33 PM
Last Post: Dino86
  S13 Front brakes in AE86 rear heshan 25 27,997 02-01-2014 12:37 PM
Last Post: heshan
