T50 gearbox
02-24-2022, 04:37 PM
T50 gearbox
I'm looking for a specific T50 part, not a bearing or gear. It is a
spacer that is used to adjust end float and is (was?) available in different thicknesses. Anyone know where l might start looking? Thanks An analogue brain in a digital World |
02-25-2022, 11:40 AM
T50 gearbox
http://www.japan-parts.eu/toyota/eu/1984...mtm#33321D
There is 5 "ring" and 1 spacer that fit your description On the input shaft: 33311F (spacer) 33311B On the main shaft: 33321D 33331B 33393A 33321B counter shaft: 33411R |
02-25-2022, 12:46 PM
T50 gearbox
Thank you for the diagram.
I will check which one l need and report back. Thanks again. An analogue brain in a digital World |
02-25-2022, 02:35 PM
T50 gearbox
33311F (spacer): 90560-6100X
X goes from 1 (1.825) to 6 (2.375) -> 1 and 4 are out of production on Amayama 33311B: -> out of production 33321D: -> out of production 33331D: 90520-270XX 03/12 -> Available 33393A: 90520-240XX 09/23 -> seems available (didn't check all of them) 33321B: 90520-230XX 26/32 -> seems available (didn't check all of them) 33411R: -> out of production |
T50 TRD gearset | DidiDex | 7 | 9,593 |
09-12-2019 07:36 PM Last Post: DidiDex |
4A-GE bellhousing on a 20 spline T50 | The Doctor | 2 | 7,242 |
09-30-2016 03:38 PM Last Post: The Doctor |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 6,920 |
11-27-2015 10:06 AM Last Post: Project D |
T50 Gearbox, Fragile ! | hachirokkos | 10 | 12,846 |
11-12-2015 12:06 PM Last Post: S.K. |
Need help identifying an unknown t50 | ditn | 10 | 13,156 |
04-16-2015 12:27 PM Last Post: ditn |
