TOYOTA COROLLA Ke70 - Restoration project
08-31-2013, 12:36 PM
In this, i've removed anything that was connected to the engine block, oil sump, oil pump, engine seals, crankshaft...The engine had a lot of RTV sealant, which became difficult to do my job in removing some parts, such as the oil sump and the oil sump plate.
The strainer with some dirty RTV wastes Oil Pump and crankshaft retainer i've arranged some time to finish the rest of the work, and removing the remaining parts, such as the pistons and connecting rods, and the crankshaft. At first seeing the pistons seemed very good, just need to be cleaned. Piston nº1 Piston nº 4 Cranckshaft Block ... Jorda MotorSport Keto Beams Project |
08-31-2013, 12:37 PM
I had a specialist looking at my engine, and he said that the engine was in very good shape, and that i was lucky to get this deal.
So, i am now in the process of cleaning and measuring all the engine clearances, but before this, there has some work that needs to be done. I've also started to removing the valves from the head. Everything ready Identification of the parts The start First exhaust valve and valve spring Too much coal at the output of the gases 1st one completed Intake valve Exhaust valve Intake valve with some superficial rusty The end for today! Hope you guys like this! Jorda MotorSport Keto Beams Project |
08-31-2013, 12:40 PM
The workshop guy, worked on the car, welding the molde into the pillar C, the work is not yet finished as we can see in the pics, but he is doing pretty well.
This is the open door to the fuel tank, waiting for the mold. The mold: The door space of the fuel tank, almost ready The next victim The victim already separated from chassis, a lot work to do in this! The mold There is no recent updates from the panel beater, and it's been going like this since April, because the guy has a lot of work with another cars from other clients, but i will post a bit of an update from the workshop, when possible. Inside view Also, i´ve bought some BC Racing coilovers and ATE super blue racing brake fluid, roll center adjusters and ae86 steering knuckles Jorda MotorSport Keto Beams Project |
08-31-2013, 12:42 PM
I´ve been working again in the engine, cleaning the coal on the piston, a lot of the dirty coal was removed, but there is still some in the valves cavities, that i will remove it in other way, by dipping the pistons into diluent or gasoline to get the coal soften and easier to remove.
Here's the pics As they were before the cleaning During Almost.. Done (But still with some coal to remove in the cavities of valves) I've been preparing the 2nd piston, today. Because, as i said before, i am using petrol to clean the pistons, to dissolve most of the coal, so it can be easier to clean it As it is Old rings And it's going to stay like this til tomorrow Jorda MotorSport Keto Beams Project |
08-31-2013, 12:43 PM
I´ve been finishing the cleaning of the pistons, they are all finished and shiny!
Piston nº2 Still with a litle bit of coal, but it's just superficial, i couldn't remove anymore Piston nº3 Piston nº4 Piston nº1 All beautiful! Jorda MotorSport Keto Beams Project |
08-31-2013, 12:44 PM
Another acquisition
South African. Surprisingly, despite beaten, is in better shape than when I bought the RS. 42000km :o Well, i've been busy... Jorda MotorSport Keto Beams Project |
08-31-2013, 12:51 PM
And now, the SAD news...
The engine was sold, 3 weeks ago, because i am unemployed and i needed the money to other stuff, the engine went to Azores, and the new owner, is also restoring a KE70, like me, so it's in good hands. I am now looking for a new engine, but i will only buy it in the next year, and i am thinking in a BEAMS! Jorda MotorSport Keto Beams Project |
09-01-2013, 09:52 AM
Unemployment is a killer, hope you get working again soon as this is a cool project
09-01-2013, 12:09 PM
Thanks mate.
I am doing some training in a company nearby, and there's 3 weeks remaining to the end, and only then we'll know if we are going to stay to traineeship. Lets see how will this turn out Jorda MotorSport Keto Beams Project |
09-27-2013, 12:36 PM
Finally the panel beater began to work again on the car.
Basically is finishing shaping the rear corner and then get it ready to take welding and finish. Jorda MotorSport Keto Beams Project |
Toyota Corolla AE86 LEVIN ( Poland) | sylwekgtir | 40 | 55,210 |
11-23-2018 10:13 PM Last Post: sylwekgtir |
Full restoration... | Blade1988 | 64 | 84,845 |
07-17-2016 11:53 AM Last Post: McGlinchey |
Another danish restoration | Duze | 61 | 71,910 |
03-20-2016 08:58 AM Last Post: Duze |
'84 ae86 restoration project | HybriD07 | 19 | 25,111 |
10-13-2014 09:20 PM Last Post: HybriD07 |
Black Limited restoration | slpery86 | 6 | 9,916 |
12-17-2013 09:22 PM Last Post: banpei |
