TOYOTA COROLLA Ke70 - Restoration project
08-31-2013, 12:36 PM
In this, i've removed anything that was connected to the engine block, oil sump, oil pump, engine seals, crankshaft...The engine had a lot of RTV sealant, which became difficult to do my job in removing some parts, such as the oil sump and the oil sump plate.
[Image: AEU86 AE86 - TOYOTA COROLLA Ke70 - Restoration project]
The strainer with some dirty RTV wastes
Oil Pump and crankshaft retainer
i've arranged some time to finish the rest of the work, and removing the remaining parts, such as the pistons and connecting rods, and the crankshaft.
At first seeing the pistons seemed very good, just need to be cleaned.
Piston nº1
Piston nº 4
Cranckshaft
Block
Jorda MotorSport
Keto Beams Project
08-31-2013, 12:37 PM
I had a specialist looking at my engine, and he said that the engine was in very good shape, and that i was lucky to get this deal.
So, i am now in the process of cleaning and measuring all the engine clearances, but before this, there has some work that needs to be done.
I've also started to removing the valves from the head.
Everything ready
Identification of the parts
The start
First exhaust valve and valve spring
Too much coal at the output of the gases
1st one completed
Intake valve
Exhaust valve
Intake valve with some superficial rusty
The end for today!
Hope you guys like this! Wink
Jorda MotorSport
Keto Beams Project
08-31-2013, 12:40 PM
The workshop guy, worked on the car, welding the molde into the pillar C, the work is not yet finished as we can see in the pics, but he is doing pretty well.
This is the open door to the fuel tank, waiting for the mold.
The mold:
The door space of the fuel tank, almost ready
The next victim
The victim already separated from chassis, a lot work to do in this!
The mold
There is no recent updates from the panel beater, and it's been going like this since April, because the guy has a lot of work with another cars from other clients, but i will post a bit of an update from the workshop, when possible.
Inside view
Also, i´ve bought some BC Racing coilovers and ATE super blue racing brake fluid, roll center adjusters and ae86 steering knuckles
Jorda MotorSport
Keto Beams Project
08-31-2013, 12:42 PM
I´ve been working again in the engine, cleaning the coal on the piston, a lot of the dirty coal was removed, but there is still some in the valves cavities, that i will remove it in other way, by dipping the pistons into diluent or gasoline to get the coal soften and easier to remove.
Here's the pics
As they were before the cleaning
During
Almost..
Done (But still with some coal to remove in the cavities of valves)
I've been preparing the 2nd piston, today. Because, as i said before, i am using petrol to clean the pistons, to dissolve most of the coal, so it can be easier to clean it
As it is
Old rings
And it's going to stay like this til tomorrow
Jorda MotorSport
Keto Beams Project
08-31-2013, 12:43 PM
I´ve been finishing the cleaning of the pistons, they are all finished and shiny!
Piston nº2
Still with a litle bit of coal, but it's just superficial, i couldn't remove anymore
Piston nº3
Piston nº4
Piston nº1
All beautiful! Big Grin
Jorda MotorSport
Keto Beams Project
08-31-2013, 12:44 PM
Another acquisition Big Grin
South African. Surprisingly, despite beaten, is in better shape than when I bought the RS.
42000km :o
Well, i've been busy... Wink
Jorda MotorSport
Keto Beams Project
08-31-2013, 12:51 PM
And now, the SAD news...
The engine was sold, 3 weeks ago, because i am unemployed and i needed the money to other stuff, the engine went to Azores, and the new owner, is also restoring a KE70, like me, so it's in good hands.
I am now looking for a new engine, but i will only buy it in the next year, and i am thinking in a BEAMS!
Jorda MotorSport
Keto Beams Project
09-01-2013, 09:52 AM
Unemployment is a killer, hope you get working again soon as this is a cool project
09-01-2013, 12:09 PM
Thanks mate.
I am doing some training in a company nearby, and there's 3 weeks remaining to the end, and only then we'll know if we are going to stay to traineeship. Lets see how will this turn out
Jorda MotorSport
Keto Beams Project
09-27-2013, 12:36 PM
Finally the panel beater began to work again on the car.
Basically is finishing shaping the rear corner and then get it ready to take welding and finish.
Jorda MotorSport
Keto Beams Project
  Toyota Corolla AE86 LEVIN ( Poland) sylwekgtir 40 54,986 11-23-2018 10:13 PM
Last Post: sylwekgtir
  Full restoration... Blade1988 64 84,799 07-17-2016 11:53 AM
Last Post: McGlinchey
  Another danish restoration Duze 61 71,809 03-20-2016 08:58 AM
Last Post: Duze
  '84 ae86 restoration project HybriD07 19 25,082 10-13-2014 09:20 PM
Last Post: HybriD07
  Black Limited restoration slpery86 6 9,907 12-17-2013 09:22 PM
