TRD Short Shifter Rattle Noise, It's Normal?
04-12-2024, 01:08 PM
RE: TRD Short Shifter Rattle Noise, It's Normal?
The flower knob is not nearly heavy enough to be effective. Tape weight to the shift lever or a roll of solder warped around the knob to see how much wt is needed to change the natural frequency. We are probably talking a large chrome shift knob to be able to add enough mass. Have you checked the transmission and engine mounts plus the attaching hardware. You can also try adding dense foam rubber inside the shifter boot.
Clicking noise from glove box | chrisae86 | 4 | 1,686 |
09-08-2022 11:36 PM Last Post: chrisae86 |
Noise Insulation for AE86 | decryphe | 1 | 3,890 |
11-03-2016 11:51 AM Last Post: mad.matt |
What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 14,805 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
Whining noise HELP PLEASE | izanagi | 10 | 11,670 |
03-26-2015 06:48 PM Last Post: Komba |
Whining noise only in 4th & 5th. | izanagi | 7 | 10,189 |
09-25-2014 07:09 PM Last Post: Uzelac |
