Testing AE86 on gravel
11-22-2012, 09:42 AM
Dino86 Wrote:Hey Zax, Hi Dino. thank you. camera man has balls. I have aftermarket rear sway bar. I tried the car without it and I did not like the feeling. Car would first roll then turn in to the corner, so I decided to put it back. I also heard rumors that people remove rear sway bar on live axle, but it did not work for me. Setup of the car: Sprigs: stock all around. I would like higher and stiffer in the back because car is compressed under acceleration. Shocks: Yellow koni all around, set to medium soft. Swaybar: front stock, rear ARC aftermarket (stiffer) ![]() ![]() Drifting - best fun you can have in your car with your pants on! |
11-24-2012, 07:33 PM
![]() toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
11-26-2012, 09:59 AM
And yes, we continued. Drifting - best fun you can have in your car with your pants on! |
11-26-2012, 10:18 AM
Yikes, how did that happen?
11-26-2012, 04:41 PM
Steering hub nut got loose from shaking on gravel. Tooths on steerting shaft got worn. We lost "steering", you can see on the video that I turn left but car doesn't turn.
11-26-2012, 04:49 PM
![]() ![]() ![]() ![]() ![]() After crash ![]() Drifting - best fun you can have in your car with your pants on! |
AE82 racecar engine testing | firehawk | 1 | 3,637 |
01-01-2006 11:53 PM Last Post: firehawk |
