The A6 Celica/Carina topic
08-17-2007, 07:51 AM
![]() Here are two of the 'single headlight' grills that I've got. I think I've got another one kicking around somewhere... Other variations of the carina lights look like this: twin round ![]() twin square ![]() And this is just a gratuitous rear 3/4 shot of this sweet looking sedan. ![]() ![]() |
08-23-2007, 08:35 AM
Here's some inspiration to help make 'later' into 'sooner'.
08-27-2007, 09:16 PM
I'm very pleased with these TA60 sedans/coupes (especially coupes), and I came up with several questions. Does it has LSD or what brakes are in front/rear? Did TA60 carinas is very different from AE86 in technical area? Is the 2T-G engine very bad
![]() Sorry or OT ![]() |
08-28-2007, 12:05 PM
My TA60 has an open diff (S-class) and LSD on the TA60 was not an option as far as I know. All TA60s have disc front, drum rear.
I think a LSD can easialy be swapped from some Celica models, same axle and same diff size. Also swapping the axle and drivetrain from an AA63 or any other model XA6X Celica should be easy: same wheelbasis. Only the Celica Supra should be a problem since it has a different wheelbasis. ![]() From what I read and heard the 2T-G engine is not bad at all but it has a bit less power and is less rev-happy than the 4AGE. I'd rather have a 2T-G in my TA60 than the 2T I currently have. ![]() The TA60 carina isn't that different than the AE86, but it is much closer to the Celica than to the Corolla, so it isn't entirely a 4 door hachi. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
08-28-2007, 10:47 PM
2TG engine is meh..but a 3T-GTE with a huge turbo hanging from the side. Puerto Rican dragracing style.
08-30-2007, 02:22 PM
saliara_power Wrote:I'm very pleased with these TA60 sedans/coupes (especially coupes), and I came up with several questions. Does it has LSD or what brakes are in front/rear? Did TA60 carinas is very different from AE86 in technical area? Is the 2T-G engine very bad The *A60 models dont come with too much flash stuff, but do have a T40 or T50 box, and a T series rear. And hydraulic clutch too. Mine was an AA60 with 3AU, which means it's stupidly easy to swap a 4AGE into! But I had something else in mind. ![]() The *A63 models are the good ones, had 10" vented discs at the front, solid disks at the rear (and internal drum for handbrake ![]() The main reason I bought a carina over anything else, is that they're so damn easy to upgrade! For example, fitting my engine. I used an ST141 corona crossmember and engine mounts, and blammo, I've got a 3SGE in the car. Fitting the 6 speed box? I removed the electric speedo drive, used one from a W57, and the original speedo cable plugged straight into that. And fit perfectly in the trans tunnel. And the most jammyest part of all... The standard T40 clutch slave cylinder fits *perfectly* to the altezza box! ![]() Or getting a stronger LSD rear end? I got an F series live axle from an MA45 celica, and it just so happens that altezza LSDs fit right in, and I've got a cusco 2 way for it. ![]() My entire project has gone like that so far, lol! All my freinds think I'm a jammy bastard, but I told them.... Doing your homework pays off! |
09-03-2007, 12:21 PM
I think the Carina front on a Celica would look great (i think Toyota did it themselves, with the Corona
![]() ![]() Check the Soapra: ![]() ![]() ![]() ![]() ![]() ![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
09-03-2007, 12:53 PM
CHeck..imho better looking then either a supra or soarer. Nice car.
Not sure about the carina/celica throug :-) A wheel to steer the front of the car A pedal to steer the rear |
09-03-2007, 05:38 PM
You probably mean this one:
![]() ![]() I found it here: http://www.geocities.co.jp/MotorCity-Race/4894/6.html But that is a corona rear-end and a celica front end. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
09-03-2007, 07:48 PM
Hmmm, just realized that is not the case here... Two different cars.
![]() This is the Corona front-end: ![]() ![]() ![]() It resembles the Carina, but it is actually not the carina. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Another rusty old carina. | roman | 8 | 16,464 |
08-20-2007 12:56 PM Last Post: roman |
Amazing -musseum ready- Celica | nmwisima | 26 | 27,902 |
03-13-2006 12:42 AM Last Post: The Doctor |
ST185 celica evo 500 | SekiguchiUeno | 2 | 5,247 |
02-25-2006 08:53 AM Last Post: banpei |
Check out that old CELICA!!! | nmwisima | 12 | 15,000 |
07-10-2005 10:09 AM Last Post: banpei |
