The best setup for autocross on very small tracks
12-22-2004, 03:09 PM
copy/paste
--------------------- Since budget is always a concern, here are some single adjust shocks with characters explained in general terms. TRD adjustable short strokes have fairly good range of these valve rates. Tokico HTS (available in the USA spring 2004) has ranges that balance compressions while rebound stays pretty constant. Koni generally have soft compression with good range of adjustable rebound. Koni single adjustables may be best bang for the buck for SOLO2 use, but it may take a while to get used to them. Tokico HTS shines in drift use and can be really comfortable in the city with some tweaking. TRD adjustables basically seems to be somewhere in between. Moto Webmaster, Club4AG Drifting - best fun you can have in your car with your pants on! |
12-22-2004, 03:39 PM
I would just use some Koni shocks. Quality is ok and there is a large number of shops in Europe that can provide customer support. If and when you decide to become serious about racing, its a small (yet expensive) step to have them rebuilt to 3 way adjustable, remote reservoir specs. They won't support very high springrates, but you should be fine with a set of 7/4 springs.
The ratio between front spring rate and rear sping rate determines the FRC. Basically it determines what sort of attitude the car has, steady state understeer or oversteer. In a true racing vehicle you want a fair amount of understeer. This ensures that the rear wheels have plenty of grip left for powering out of a corner. The more power you have the more this effect is needed. Rotating the car into the corner now has become much more difficult, that where driver skill comes into play. Rotating the car on throttle and braking inputs should prevent understeer. A wheel to steer the front of the car A pedal to steer the rear |
Best quality Diffs | gh0st | 1 | 1,561 |
07-03-2022 07:49 PM Last Post: banpei |
Best Induction Kit / Set up | chrisae86 | 20 | 16,161 |
06-10-2020 10:59 AM Last Post: Lykowsky |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 7,772 |
Rim width. Which is best.... | Dino86 | 5 | 7,030 |
Small Port Swap | Alex170984 | 1 | 4,351 |
11-21-2016 01:46 PM Last Post: Alex170984 |
