The dark side
01-08-2013, 11:26 AM
The dark side
Right I'm considering going over to "the dark side" lol
20v install I have no problem with the mechanics of the swap but what I'd really like to know is about the ecu. Currently the car has a 16v engine with a Freedom ecu running through a stock blue top loom. I would like to keep the Freedom ecu and that would mean keeping the stock blue top wiring outputs from the ecu. Freedom can run a 20v and I can tune it but will it be possible for me to modify my loom to suit the 20v engine ? Thanks for help with this. An analogue brain in a digital World |
01-08-2013, 11:32 AM
The dark side
I dont see how it will work? AFM to MAP based?
01-08-2013, 11:44 AM
The dark side
MAP based
Apart from vvt are there any other differences with the engines ? The ecu can run Alpha n for the itb's An analogue brain in a digital World |
01-08-2013, 05:48 PM
The dark side
What ecu are you running? Omex/ Emerald/ Motec/etc?
Should be not problem if its a proper ECU! If you want it cheap a little bit of soldering a lot of reading and crossreferencing. There are a few thing different on a 20V BT, idle up valve, rpm signal etc. Not saying it can´t be done but lot of work and still a 20year old loom! And you gonna need a remap anyway, obviously... BUT I´d recomend a new custom loom, you can buy the ecu plug with wires/ pins seperate for your ecu (if its no piggy back shit) and use the OEM senders/ connectors and solder it to the new loom, this is also a good way to ditch the dizzy (and avoid buying a relocation kit) for a coil pack. I´ve just done this at work, 20V blacktop on omex using a new loom with the OEM plugs. Very easy to build and a lot neather as a chopped OEM loom. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
01-08-2013, 05:54 PM
The dark side
fax0815 Wrote:What ecu are you running? Reading carefully before giving an answer can help a lot totta Crolla Wrote:Currently the car has a 16v engine with a Freedom ecu running For me I don't see any problem using your current ECU for a 20v. I would have to watch again my 86club to be 100% sure, but I'm pretty confident on the fact that Tsuchiya's Trueno run with a Freedom ECU. |
01-08-2013, 06:05 PM
The dark side
Project D Wrote:fax0815 Wrote:What ecu are you running? How exactly does your post help? I start by naming freedom ECU´s, fell free to add more : Motec, Vipec, Emerald, Omex, Haltech, Trijekt, Bosch, Megasquirt... Edit: What a stupid company whould give themself such silly name? It´s like beeing a BMW main dealer and having "new cars" as a company name... or beeing a company that does wooden shelfs naming themselfs "wood"... Sorry no expirience with a so called "freedom ecu", sorry... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
01-08-2013, 06:11 PM
The dark side
Freedom is an ecu's brand !
http://www.e-freedom.co.jp Omex motec etc.. are "standalone" ECUs, not "Freedom" ECUs |
01-09-2013, 12:09 PM
The dark side
Hey no problem guys, there has been some confusion over the
naming of the ecu before and I forgot that "freedom" it seems can be a generic name for a programmable ecu. I'm sorry I wasn't a bit clearer about that. Some valid points about the idle valve and my ecu can control the 20v idle valve if I can find the output pin from the ecu. There is also a chance that it can control the vvc too. An analogue brain in a digital World |
01-09-2013, 03:05 PM
The dark side
http://t2.gstatic.com/images?q=tbn:ANd9G...n41t-klbJ1
The original picture was available on club4ag, but the site seems to be down |
01-09-2013, 05:22 PM
The dark side
aaah....
Perfecto Thanks An analogue brain in a digital World |
Fibreglass side mirror options? | 4000GT | 11 | 20,789 |
04-16-2011 03:30 AM Last Post: 4000GT |
4age intake side (port) dimensions | Uzelac | 15 | 35,492 |
03-03-2011 12:43 AM Last Post: Uzelac |
OEM side mirrors AE86 (Levin coupe) | Okami | 2 | 5,334 |
05-24-2010 08:37 AM Last Post: Okami |
What side mirrors fits on the Hachi? | Allexz | 4 | 6,587 |
08-06-2009 09:35 PM Last Post: Ivan141 |
How to dismount side skirts? | pedro-siR | 3 | 4,184 |
03-14-2008 05:24 PM Last Post: pedro-siR |
